Rear door fixed window is loose (behind functional window)
The whole window piece not just the square decorative piece
I started getting intermittent wind noise (depending on how the door was last closed I guess)
While heating the car one morning with fan on high, I came out to car and could hear fan wind whistling out the back side of the panel I circled.
I can lift the back edge of this window and see the round clips that should pop into holes in the door frame not seating.
If I were to continue to pull it up I'm sure it could be ripped off and gain access to the vehicle.
I ask here because I may not understand the construction/adherence of this part.
Proper fix?
In case they just try to fist bump the clip back in its frame hole or randomly start applying glue?
I am not referring to the decorative "square" that is on the rear part of the fixed window - referring to the whole window panel
Bob
I too had the same issue, and had it in to my dealer to have it repaird. The problem is I now have a whistle at speeds over 60mph. I've had it back to the dealership twice - they claim it is fixed but the whistle persists.
Had anyone else had this issue? I can eliminate the whistle with some carefully placed tape, but I'm not interested in driving around with a taped up window. The dealership seems clueless and clearly isnt test-driving the vehicle to check if the issue is resolved.
