Retro fitting leather electrical adjustable seats 2020+
Old Aug 13, 2024 | 09:37 AM
kylemcbrides@hotmail.com's Avatar
4th Gear
Default Retro fitting leather electrical adjustable seats 2020+
Hello, recently I purchased a new 2024 defender commercial, unfortunately I missed the leather seat when ordering.
i have now purchased hse commercial front seats and was wondering will the harness plug and play or will i have to get this sorted too?
Old Aug 13, 2024 | 10:17 AM
CincyRovers's Avatar
I'm pretty sure that it is a completely different harness for the full power seats. Also, this is a US-based forum and we don't get the commercial here, but most things are applicable to Euro-spec cars.
Old Aug 13, 2024 | 10:24 AM
4th Gear
Ok after speaking to a breaker, from 2024 on they think the change is all on the seat itself ie power the module in the seat using the same plug and it may just be a case of coding
Old Aug 13, 2024 | 03:53 PM
stevemfr's Avatar
Not seen that done on a L663 yet, but you will almost certainly need the CCF (car configuration file) change. Google GAP Diagnostic IIDTool.
Most of the harnesses are modular, so your breaker could be correct in that you're ok with ccf editing. Sometimes changes to the harness are needed, but it should not be an insurmountable problem.
Old Aug 13, 2024 | 04:05 PM
4th Gear
Seats arrive in the next few days, I’ll be sure to update
I’ll have to invest in the gap Id
Old Aug 14, 2024 | 05:42 AM
Parukas's Avatar
where did u get the chairs from and what was the cost? Thanks!
Old Aug 14, 2024 | 05:51 AM
Jomara's Avatar
Kyle
Here's a link to the parts catalogue, hopefully this will help you. I do know there are seat memory ECU units and I'm sure as the other guys have said the car will need to be coded to recognise they're fitted. Chris Royle at Royle Prestige & Performance might be able to assist with this as he carries out numerous retrofits.
https://store.landrover.com/parts/in...nd/land-rover/
Cheers
John
Old Aug 16, 2024 | 12:50 PM
4th Gear
Ok, so the rails, wiring etc where all completely different, not just a case of changing harnesses etc
what I did do was just swap the leather over.
this worked really nice, bubble wrap effect still on leather 😂
Old Nov 22, 2025 | 11:33 AM
manu's Avatar
Thank you for sharing your upgrade.
Was it a straight swap for the seat itself?
Did you manage to memory seating setup as well?
clb87
Mar 1, 2023 05:44 PM
hewpac
Sep 21, 2021 07:57 AM
Simon14
May 17, 2021 03:51 PM
rovernoob
Mar 15, 2015 09:35 PM
