Rusting Exhaust tips on V8
Old Feb 3, 2024 | 07:43 AM
Quick's Avatar
Default Rusting Exhaust tips on V8
Anyone else have issues with their exhaust tips rusting? Mine are pretty bad, and on both sides. Guess it needs to go to the dealer, but this was unexpected.
Old Feb 3, 2024 | 08:30 AM
SilverSFR's Avatar
Unfortunate yes. But easily removed with some steel wool and Brasso or like metal polish. The tips are already brushed. Raw stainless still requires a bit of maintenance now and then. Start with 0000 steel wool and some Brasso. Then buff with an old towel. If you choose the dealer route let us know there response. Post some before and after pictures so future topic readers can benefit.
Pro tip: Take a microfiber towel and lay it flat. Then take your 0000 steal wool and spread it out a bit and lay it on top of microfiber. Douse some Brasso on top. Use this setup to buff your tips In one motion pulling on the towel from side to side. Sorta like shining your shoes.
Old Feb 3, 2024 | 10:36 AM
outcast's Avatar
could also a leaky rear door seal? check the top of the rear gas strut for signs of rust too.
Old Feb 3, 2024 | 10:40 AM
chpsk8's Avatar
For sure I'd take it back and see what they say. If they say it's normal I would use this stuff t clean the rust off.
Amazon Amazon
Then I would coat them in this.. (If they replace them I'd coat them in this as well. I put it on my muffler and tips when I bought mine and we're halfway through a salty winter with no signs of anything happening.)
Amazon Amazon
Old Feb 6, 2024 | 07:38 AM
nashvegas's Avatar
I found this bulletin JLR issued in Nov 2023 about it. Apparently, no fix yet though - I speculate that they're having to build the business case, deal with a supplier on costs, etc. I'm not sure what else they can do except replace all of these mufflers as those tailpipes are integrated/welded on.
File Type: pdf
Old Feb 6, 2024 | 08:08 AM
Quick's Avatar
Thanks. That's disappointing. Don't really want to deal with constantly cleaning them, but guess I'll deal with it for now. Will report to the dealer when I take it in for service.
Old Feb 6, 2024 | 10:43 AM
nashvegas's Avatar
The document I found is notable in that it's a "status" not a determination or remedy. I'd bet after some time they'll have an actual remedy. So don't give up hope yet. Normally they release these types of docs when there's a problem being widely identified in the field, then eventually they'll decide on a fix. Then a new document comes out.
I became familiar with their "documents" a couple years ago when my 2020 kept doing the "not restarting at stoplights from auto start-stop" and they kept issuing documents saying "tell customer to turn off stop/start", then finally a remedy came out a year later.
Old Mar 8, 2024 | 11:55 AM
Chris.Gio's Avatar
how much is wholesale on a new exhaust plus dealer install? I’d rather they cut us all a check and we go aftermarket!
other idea: getting a quote to cerokote the factory exhaust.
IBarelyKnowEr
Aug 12, 2024 07:09 AM
TheEscapist
Dec 30, 2023 01:47 PM
lawnmowerhombre
Dec 5, 2023 09:37 AM
Paulvfr
LR2
Feb 5, 2022 09:28 PM
sblvro
Oct 3, 2021 04:57 PM
