Spacers with 23 inch wheels
Old Jan 11, 2024 | 06:23 PM
ColonelBlood's Avatar
Default Spacers with 23 inch wheels
Ok got vossen uvx 23 x 10 custom. I have 30mm spacers already. Going with 295/35/23 michelins. Do I keep the spacers? I have a V8 90 with 22x9 already using spacers. Will they work with the vossens?
Old Jan 18, 2024 | 09:05 AM
Ehloo's Avatar
you shouldn’t have to need the spacers unless you wants a very aggressive stance poking way outside of the fender. you will prob run into some major running issues. The uvx has more aggressive offsets and it should look good
Old Jan 18, 2024 | 03:14 PM
SilverSFR's Avatar
Please post pictures? I see Khan and Chelsea sell 23's as well so I'm sure they should fit.
Old Jan 18, 2024 | 11:49 PM
Default 23's. Also did black interior bolts
I am waiting on them. I already have it lowered with 30mm spacers all around. Waiting to see. Wheels are only an inch wider than the stock 22's
Old Jan 19, 2024 | 11:28 AM
Ronin Defender's Avatar
23" wheels on a Defender say everything I need to know.
Old Jan 20, 2024 | 12:35 PM
Ehloo's Avatar
it’s not just about wheel width. width and offset determines wheel fitment. if the wheel is 1 inch wider you are .5 inch pushed further out to the fender which is about 12mm more aggressive offset. most aftermarket wheels run around 30mm offset. stock wheels are in the 40’s.
30mm with aftermarket wheels will be pretty aggressive. i am running 20mm spacers in the rear with aftermarket wheels bringing me down to around a 10 offset. it looks good and want to do the front also but the front is where you get rubbing.
i will be running Urban widetrack fenders. i dont believe the fenders actually make the car wider. just looks wider
Old Feb 3, 2024 | 04:12 PM
Default Spare delete
Old Feb 5, 2024 | 03:06 PM
starbai's Avatar
any updates? would love to see the 23"s on it.
Old Feb 5, 2024 | 03:21 PM
soulsea's Avatar
This thread is about spacers ... any more off topic, mesogenistic, political and insulting posts the thread will be closed and holidays will be handed out.
Thread edited and posts deleted to reflect the above.
Babadook
Nov 17, 2023 08:38 AM
ElVerde
Dec 12, 2021 12:43 PM
16Fullsize
Range Rover L405 (Fourth Gen)
Feb 25, 2020 10:17 AM
jringeno
Apr 5, 2017 12:15 AM
GeoA(Atl)07SC
Appearance & Camping Set Ups
Jun 2, 2010 08:29 PM
