Spacers to avoid rubbing?
my shop was trying to push me on the 275/60/20 settup but hearing the possible issues i was glad i went with the 55 series instead.
the 60 do look so much better. No matter what some inner fender modification will need to be done. it could be as simple as trimming and pushing back the liners with zip ties etc. pretty common stuff when going with bigger tires
this was all new for me also. never had a lifted truck with big tires. learning a lot as i go
A Faceless Man (05-01-2021)
Rubbing with the 275/55/20
I am facing the same issue, I tried installing BFG 275/55/20 on my Redbourne alston wheels but they were rubbing and I didn't want to trim anything, whats confusing is that even if I raised the defender into offroad mode, it still rubs.
So im not sure if the offset of the wheels is creating this, and would a lift solve the issue (my dealership officially stated that any change in the suspension such as adding lift rods will void the warranty immediately) which sucks as there is no way to lift the defender for bigger tire.
My wheels specs are:
20x8.5
Offset 25
Back spacing 5.730
20x8.5
Offset 25
Back spacing 5.730
