Spacers for wheel arch protector
Old 10-26-2021, 05:38 PM
RR2Dfndr's Avatar
Originally Posted by Defendit..
With these wheels I would not go wider than 22mm or max 25mm.
( Only backside you need to cut/shave the wheelstuds a few mm)
Be sure to use an high end Brand with good fitment, studs and bolts. No vibrations if properly installed ( Torque 140Nm)
Do you know if you have to cut the wheel studs for 30mm spacers? Or what size spacers do you not have to cut the studs?
Old 10-26-2021, 05:42 PM
RR2Dfndr's Avatar
Originally Posted by 2045
Question about the arches, does it really widen the car a bit or just give the visual look of wider look but doesn’t really change the width?
I’m on the fence about them and find them both (with & without) look great in different angles. I would only add them if they give the real world difference in width.
It does widen the vehicle. I believe by 1-1.5inches each side. That’s why it needs spacers or new wheels with more offset to make it look aggressive.
Old 10-27-2021, 12:02 AM
Ehloo's Avatar
usually with spacers that large they give you new studs. you need a certain amount of thread engagement to be safe
Old 10-27-2021, 12:06 AM
Ehloo's Avatar
all defender oem wheel options have the same offset beside the 22’s
41.5 for the 19 and 20’s
44.5 for the 22’s but they are wider hence the higher offset
30mm is the perfect offset to sit flush with fenders.
i am running aftermarket wheels with a 10mm offset and they sit flush to the large fenders
with a 30 spacer it will bring your net offset close to 10
RR2Dfndr (10-30-2021)
Old 10-27-2021, 06:29 AM
Defendit..'s Avatar
I thought the 20" are 8.5" width, that's why I did recommend the 25mm spacers.
Old 10-27-2021, 08:08 AM
TheJMG's Avatar
Has anybody spaced steel wheels?
Old 10-27-2021, 10:07 AM
clubguy's Avatar
yes it is.
That's what I have too.
Old 10-27-2021, 12:35 PM
Defendit..'s Avatar
Yes, I did
No problems with it, did even 119 Mph in Germany ( Alloy Wheels with the Goodyear Adventures)
Be sure that they are good aligned against the spacers and torqued as spec,140Nm
The following 2 users liked this post by Defendit..:
Ace7711 (11-03-2021), TheJMG (10-28-2021)
LR03NJ
08-24-2017 09:02 AM
jringeno
04-05-2017 12:15 AM
tastandish
04-02-2017 01:47 PM
Justonropes
Defender
12-19-2012 09:50 AM
beekers
12-06-2006 02:11 AM
Quick Reply: Spacers for wheel arch protector
