Spare tire forward tilt ?
Old Sep 6, 2025 | 02:06 PM
Darover2's Avatar
Default Spare tire forward tilt ?
Folks,
Would any if you be so kind and check the side profile of your spare wheel and see if you also have the forward tilt.
I finally received my 5th tire/wheel combo and removed the oem spare with the tire cover. However, the spare seems tilted forward and I’d like to know if its normal or not as I never noticed it before.
see pics and thanks for any input.
Old Sep 6, 2025 | 02:56 PM
CEHansen's Avatar
Default Beats the alternative
That’s normal. Trust me, it beats the alternative.
I got rear-ended on I-5 yesterday.
Anyone recommend a good body shop in the greater Seattle area?
Old Sep 6, 2025 | 03:53 PM
Darover2's Avatar
ah crap that sucks. Thanks for your reply, I studied it and as you confirm, it has to be normal since the wheel/rim is perfectly resting on the spare support bracket all around so it is what it is 👍
Old Sep 7, 2025 | 12:11 AM
Vadiable Paradox's Avatar
Originally Posted by Darover2
Folks,
I noticed that too when I received mine and thought that it was a nice aesthetic touch - there are very few things in this world that are truly square, or parallel, or vertical, or horizontal.
If I had to guess for the reason for this other than aesthetic - I'd say it makes putting the wheel on the bracket easier for it wouldn't want to slide down, but there's something more essential than that - if you back into a wall, you get a gentle warning and torsion stress on the bracket first instead of a hard slap and stress on the whole tailgate structure.
Take it with a grain of salt, that's just my imagination.
Old Sep 7, 2025 | 07:04 AM
AVLDefender's Avatar
The slight tilt forward allows water to drain and not collect in the wheel. Totally normal.
Old Sep 8, 2025 | 12:05 PM
WTFChuck's Avatar
Actually, I don’t believe the engineers designed any tilt in the spare tire mounting to assist in getting the wheel back on the bracket, as there is a threaded post included in the rear under-floor storage area, along with the jack and lug wrench. This is used in both taking a tire off the vehicle and replacing the tire on the vehicle as well as aiding when lifting the heavy tire/wheel combo up onto the spare tire mount.
And I also think that instead of any ‘tilt’ being designed in as a ‘gentle warning’ when backing into a wall, the engineers went through the process of including multiple cameras and audible warnings to ensure that one DOESN’T back into a wall. Must be effective, as I haven’t backed into any walls in my nearly four years of ownership. I’ll stick to relying on the cameras and audible indicators instead of waiting until I feel my spare tire make contact with any walls to let me know I’ve gone too far.
Old Sep 8, 2025 | 04:56 PM
Husky44's Avatar
<makes mental note to look for this threaded post next time I remove the spare>
Old Sep 9, 2025 | 01:56 PM
WTFChuck's Avatar
If I may ask, what make and model of tire is on your Defender? I like the tread pattern, aggressive without being too ‘chunky’. How is the road noise with those tires? Any annoying drone at highway speeds?
Old Sep 9, 2025 | 03:01 PM
CincyRovers's Avatar
Those appear to be the Goodyear Duratracs.
Drednot
Nov 11, 2024 08:33 PM
Brandon318
Nov 27, 2023 02:19 PM
Fighter13
Aug 11, 2017 01:52 PM
