suspension (dumb question)
Old Feb 8, 2023 | 04:25 PM
  #21
Nuckle's Avatar
Originally Posted by NoGaBiker
LOL, a setting? What's the setting called "Racing for Pinks?" Ask them to please show you the button that allows for that 3" height differential because you like it and want to dial it up every time you park.
I chuckled.
Old Feb 8, 2023 | 09:13 PM
  #22
Jiman01's Avatar
“Setting”…😂🤣
Maybe they should integrate that into ecomode to shave off a MPG 🤡
Old Feb 9, 2023 | 08:30 AM
  #23
notourist's Avatar
i'm still waiting for my service appointment. but with LR's service comment that it's a "settings" issue - i wonder if they're just going to put the car in auto access height and call it a day. i haven't tested it out yet. but i assume that would "fix" it because the car will be at its lowest height and prevent the front from being lower than the rear...
Old Feb 9, 2023 | 08:44 AM
  #24
_Allegedly's Avatar
That should not happen if they are able to duplicate the problem and they follow the service manual.
Starts on page 3072 of the P300 manual in this link and goes for many pages including diagnostic procedures.
Page 3121 starts the diagnostic procedures that they should follow.
Old Feb 9, 2023 | 02:23 PM
  #25
this_account_is_mt's Avatar
It wasn't a tech that made that comment. Let your service advisor know how to duplicate the problem and they should have no terrible fixing it. The people you get on the phone are just schedulers that don't know anything about cars and are instructed to never say what a problem is over the phone even if they know it, too much liability
Old Feb 10, 2023 | 10:24 AM
  #26
notourist's Avatar
If anyone is interested - here's an update: Dealership/service took a look at the car this morning. Their response: Since there are no fault codes and the system "sometimes depressurize which can be normal. as long as it fills back up and there no lights on that is normal". So they will not fix.
Old Feb 10, 2023 | 10:39 AM
  #27
Jiman01's Avatar
Not sure how satisfied you are with that answer but it might be time to escalate it higher up
Old Feb 10, 2023 | 10:58 AM
  #28
racerpeter's Avatar
Fwiw, I had a similar issue (suspected air leak because one corner of the car sat lower after being parked overnight), and was told the same thing by the dealer -- no fault codes found/no issues found, won't fix. In my case, I think they were probably right because where I park my truck is not very level, and I've not noticed issues anywhere else (stop lights, other parking spots, etc). But then I also have auto access mode enabled. Might be time to turn that feature off for a bit to make it (hopefully) more obvious if there's a slow leak.
Old Feb 10, 2023 | 11:10 AM
  #29
Did they let it sit overnight to try to verify the problem? If not, their answer is a cop out. There are tons of warrantable issues that don't generate faults. Do oil leaks generate faults? Almost never. But those are still warrantable.
Dealer tech here (MB) and this is a bull**** answer from someone being lazy. Find another dealer or put pressure on them. Air suspension shouldn't drop on one axle/corner over one or two nights. This failure is easy for them to test and quantify, they just need a very small amount of effort and an undisturbed parking space for a couple days at most. Air suspension issues commonly don't produce fault codes, that doesn't mean there's not a problem.
Old Feb 10, 2023 | 04:00 PM
  #30
inater's Avatar
Ya that's bs.... its funny how it really does all depend on the dealer. The car should not be consistently sagging like that every night. I would show them the work order that I posted and ask them if its similar. They could easily perform the same tests.
