suspension : front down/rear up
Old Sep 29, 2021 | 08:23 AM
  #31
Jati's Avatar
Default Front air suspension sagging
I’m having the same issue
Old Sep 30, 2021 | 06:37 AM
  #32
Jati's Avatar
Originally Posted by FzyPChz
More info: “Have the service dept specifically check the front valve block assembly which controls flow to/from the front air springs. The assumption is that there would be a leak somewhere in the normally closed valve/axle cross link air path between LHS and RHS front air springs, as both front springs are deflating when parked.”
I, too, will be dropping my Defender off for service.
The same thing is happening with my 2020 110x. Front sags down overnight, rear at normal height. Best guess is that there is a slight leak in the front system somewhere. I checked the couplings at the shock tops and at the front valve block. Can only now think to leak check the entire EAS system. Local dealer has no service availability until November.
Old Sep 30, 2021 | 11:25 AM
  #33
Jati's Avatar
Ran the issue to ground…. Early build 2020 Defenders have defective front air struts that require replacement ☹️ Found out today that there was a TSB for the issue, back in late 2020. That TSB was resigned and is now just in the maintenance manuals. I suppose if no one complained about the issue JLR didn’t say anything 🤷🏼‍♂️
Old Sep 30, 2021 | 12:01 PM
  #34
FzyPChz's Avatar
unfortunately, you’ll have to go to the dealership to get it fixed under warranty.
Old Sep 30, 2021 | 12:26 PM
  #35
Jati's Avatar
And here it is:
Vintage12
Jan 22, 2021 11:57 AM
RA021226
Apr 27, 2018 01:46 PM
Gerard
Feb 5, 2012 02:21 PM
DiscoMeadows
Jan 2, 2012 05:23 PM
Firsty
Feb 22, 2008 08:00 AM
