TDI Tune
#21
Greetings every one ... .Just installed this today, and it was a bit of a bear for BOOST1 fitting. Barely reached it, but ... was done in the end.
When I ordered this device I got it with BT connectivity. It got a mystery object that might be the BT "dongle". Now, where would I connect this ? It seems to have the same type of connector as the unit itself, but no extra port where to connect it (!?).
No, there is no explanation on the manual or install instructions they've sent, and no support today (for some reason they are closed).
Any help is appreciated !
#22
#23
Hard to beat this pricing for Black Friday. It's less without optional Bluetooth to control the programs from an app but I can't see going without that feature. I'm in. Ordering tomorrow. Thank you @DefXBill
Data sheet for p400 attached.
#26
I'm a little suspicious of the performance/efficiency claims for these modules. In principle it is possible to improve both if the stock setup is instead optimizing emissions - that's what a more regular custom tune might try to do. These are apparently achieving gains simply by spoofing the sensor data causing higher fuel pressure and higher turbo boost, which is a rather blunt tool. I can see some performance gains there, but not efficiency gains. It's also notable that the datasheet goes into considerable data on performance gains for the different maps, but says virtually nothing about efficiency. I'd also be concerned about the long-term effects on engine components.
The following 2 users liked this post by Muppetry:
Iceman153 (12-03-2021),
Mechano2020 (12-03-2021)
#27
I just ordered mine last night. The offline turbo lag is the one sore spot of this engine—plus the fact that it sounds a little like a blender. I am next looking for a more simplified solution to create a different exhaust note short of a complete exhaust replacement system. It just needs a little more air to breathe.
Has anyone seen whether K&N or anyone else has released high performance air filters for the P400 I6?
GrouseK9 (12-01-2021)
#28
Bill, were your wire leads both marked “B1”? Or B1 & B2 ? My TDI kit arrived yesterday and both of my leads have a blue tape with B1 on both. Since the individual wires are different colors… I’m assuming wire leads are specific to sensor 1 & 2 & TDI mismarked one of the jumper leads??
#30
I have been running the TDI tune for a couple of weeks now and I must report I am very happy. The throttle response off idle is the most noticeable, almost eliminated the turbo lag. I like the idea of not changing the ECU map, just trick the sensor inputs much like the Johnson lift rods do, but in this case the boost sensors. And it is easy to put back to stock. I highly recommend this mod. It was an easy tool-less install, although one of the sensors is tricky to access. They claim an increase in MPG with HP gain, coming from the modified Diesel truck world this is a new experience for me. So I agree with their increase in HP claims, guessing I’m around 450 now plenty for me. It was easy to find a location to mount. If you go on their website and they don’t show one for our P400 application email them, they have one.
