TFT Instrument Cluster Install (LR147553)
Old Mar 17, 2023 | 02:34 PM
merosenb's Avatar
Default TFT Instrument Cluster Install (LR147553)
Has anyone here tried to swap out an OEM analog/digital display (LR147552) for an OEM full TFT display (LR147553)? My '23 Defender came without the full TFT but I've talked with LR and it's possible to order the instrument cluster part. Does anyone know if the install is plug and play or any reason why the new cluster wouldn't fit/connect properly? Many thanks to anyone who has insights or experiences.
Old Mar 17, 2023 | 03:46 PM
Balleur's Avatar
It should fit but needs to be vin coded.
i would
like to buy the full digital from
you! As mijn 23 x comes
with analog…
Old Mar 17, 2023 | 03:49 PM
merosenb's Avatar
Hi there - sorry, but I have the same analog cluster. I am planning to order the TFT from LR and have it installed. You can do the same as the part is not restricted and is available for purchase. However, there is a backorder and the Parts dept could not validate for me if all that is needed is the new cluster assembly. I'm hoping someone here can help with that validation. Also, what does "VIN coding" mean?
tt6368
May 28, 2022 01:12 PM
04disco2va
May 7, 2021 06:21 PM
Wesley Cantrell
Oct 21, 2017 08:48 AM
Uss
Defender
Aug 17, 2017 07:58 AM
Litespeed19
Nov 3, 2010 08:51 AM
