Top rear fin?
How much more clearance do you need and what kind of opener do you have? Almost all openers can be very easily adjusted to travel a little higher.
Any Defender (90 or 110) trim level you have built in the NAS will have that fin. If you go to the configurator, it appears that all trims levels and body styles have it because it contains all of the nav, etc. antennas.
That could have been a ROW (Rest of the World) spec or one of the many myriad options that are no longer offered.
I can get under it, but only on one side, it is about 1.5 cm too low at the worst point.
