Towing an Airstream Basecamp 20x with 110 p400 questions
Old Jan 1, 2024 | 01:49 PM
wlindsey@gmail.com's Avatar
Also make sure you don’t overweight the back of the trailer as that adds sway. You want to make sure you have enough weight in the front
Old Jan 1, 2024 | 02:34 PM
MackT83's Avatar
We have crossbars and a Thule roof box. That spare tire takes up almost the entire roof if we were to switch to a roof rack. I’d like to leave the spare tire on the back. Surely there’s some sort of modifications we can do to the trailer tongue.
Old Jan 1, 2024 | 09:05 PM
TeddyG's Avatar
I'm using something like this CURT Class 3 Ball Mount (2" Shank, 7,500 lbs., 6" Drop, 14-1/4" Long) - Accessory Warehouse
It only messes up tow assist which I don't use.
Small airstreams are super easy to tow.
Old Jan 2, 2024 | 11:59 AM
RH5555's Avatar
Modifying the trailer tongue is the gold-standard fix. Although extending the vehicle hitch may seem just fine, there must be some reasons that JLR do not want you to do this. Probably something to do with emergency maneuvering dynamics. Certainly something to do with the tow assist trailer backup feature. If you use a 14" long shank, you should also probably half your maximum tongue weight as the twisting action on your rear cross member is going to be amplified. Look at what you're connecting to - do you really want to add a 14" lever arm to this?
For the Bascamp, all I can suggest (short of getting out your welding gun) is swapping out the front jack for a removable one and if that doesn't give you enough room, modify that humongous propane tank holder for a smaller one.
Old Jan 2, 2024 | 12:07 PM
DefenderSISU's Avatar
Default Towing
I tow this Ibex 23RLDS with a max weight of 7800 pounds and I don’t use a WDH or sway bars just the red arc brake controller. I have had no problems at all.
Old Jan 2, 2024 | 12:08 PM
MackT83's Avatar
do you have problems with the spare tire?
Old Jan 2, 2024 | 10:21 PM
MNDefender's Avatar
We have a 21’ Grand Design that we pull with our P400. We removed our front jack and added a side mount jack. The rear door opens enough to grab the dogs, with the spare tire mounted.
Don’t have a picture of the new jack and the trailer is parked for the winter.
https://www.etrailer.com/Trailer-Jac...8aAvvsEALw_wcB
Old Jan 3, 2024 | 11:47 AM
Default Had jack moved back
No I had the jack moved back about a foot or so.
I think I will be changing out my coupler to a Lock and Roll one. But still have not decided.
Old Jan 3, 2024 | 06:03 PM
richmeyer's Avatar
I’ve got the Lock N Roll on my Taxa. Can’t beat it for articulation and connection security, but it is a bit more finicky to hook up. I took to always carrying a mallet with me, it can require a bit of persuasion on occasion.
Old Jan 3, 2024 | 06:22 PM
Husky44's Avatar
Does that allow you to get the rear door all the way open or just partial?
