Tracking Defender issues
My 2020 Defender 110 has has the windshield wind noise A-column cover falling off problem, a windshield that cracked for no reason, slow-to-respond shifter, and finicky keyless entry issues. 15k miles.
Keyless start
Have had my ‘21 Defender 110 for only a few weeks (preowned, 17k miles), and it won’t start unless you place the fob precisely positioned under the steering column. Called service department and they said might need a module replacement. Anyone have this issue? Replaced battery but didn’t help. Both fobs do this.
Hey Okie - I have a 2022 and had the exact same problem with the key fob. Try cycling on and off the Auto Start/Stop feature button once the Defender is running and see it that fixes the issue. Also use your key fob outside the vehicle to lock and then upload the Defender. I ended up doing both of these things and I have not had a problem with the key fob moving forward.
Royalist (11-12-2021)
2022 Defender 110SE.
No mechanical or electrical issues to report. Runs like a champ.
Have a sunroof or headliner very minor rattle over the drivers side. Not terrible or annoying but that’s the only fitment issue. Otherwise interior is solid.
DefenderSISU (10-07-2023)
Other than that, few screen blackouts, left driver side speaker may be blown, and squeak in instrument cluster left side plastic surround squeaks. Will have it all sorted when it goes in for the Recall/TSB. No real issues though, love the car.
EDIT: Just passed 8,000 miles today.
My 2021 P300 S had been great with no issues up until a few weeks ago. After about 1800 miles, I started hearing a relatively slight whirring noise along with somewhat depleted engine power. Took it into the dealer and was told I need a new turbo which is on order and now a few weeks away from showing up at the dealer. I was also told it was safe to drive in the mean time and no other collateral damage would be done.
All of a sudden on the highway yesterday, the whirring gets way worse and engine power is almost nothing. I get off immediately and it’s currently a struggle to get the truck up to 30 mph with nearly flooring the gas pedal. There’s also some shaking that happens when idling at red lights. Definitely dangerously slow and not safe to have on the road. Bringing it in first thing tomorrow morning and demanding a loaner until the issue is resolved. I just hope whatever is wrong now isn’t going to put my truck out of commission for a seriously long period of time.
It's pretty surprising that it didn't go into limp mode before that happened. Not even a check engine light? Best of luck getting it resolved quickly.
