Tyre/Road noise with 22 inches wheel
Old Mar 3, 2022 | 04:13 AM
Stifmeister's Avatar
4wd High
Default Tyre/Road noise with 22 inches wheel
Hi guys, The previous owner fitted aftermarket 22 inches wheel with Michelin Pilot sport 4 suv. I found that the tyre noise are horrendous when driving during both low and high speed. Also it felt very rough when hit small pot hole. Thinking of going back to 18 or 20 wheels. For those with 22 wheel, do u feel the same? What do you guys think ,is it because of the tyre?
Old Mar 3, 2022 | 11:57 AM
maxmk8's Avatar
tire sounds fine from a brand perspective, maybe it’s an alignment issue ?!
But I would probably downsize it from the rap video special to oem.
If you have a P400 you can’t fit 18”s
Old Mar 4, 2022 | 10:47 PM
Ehloo's Avatar
22’s have smaller sidewalls, less tire and you will feel bumps and pot holes much more.
as mentioned road noise from one of the best tires every made is probably an issue with alignment
if you want to hear real road noise try some all terrain tires
Old Mar 5, 2022 | 09:46 AM
Count Laszlo's Avatar
I put Michelin Pilot Sport wheels on my wife’s Mercedes and although they’re outstanding if not the best tire out there, they’re incredibly noisy. I’m not sure if they’re made to be quiet versus handling and stickiness. Just a thought.
Also, 22” will be harsher on any vehicle. Trade offs.
Old Mar 5, 2022 | 10:25 AM
maxmk8's Avatar
what sort of Mercedes? And which tires were on it prior
Old Mar 5, 2022 | 12:41 PM
The Insider's Avatar
Wheel weight between two wheels of equal size can differ greatly and contribute to unpleasant feel in both steering and driving behavior. These aftermarket wheels might be notably heavier than the factory wheels, but also wider (or narrower). The tyre size might also be a contributing factor if they have reduced sidewall height. The factory tyre size for a 22" wheel is 275/45/22. Can you confirm that is the size currently on the vehicle?
Lastly, sometimes tyres are simply overinflated and you should confirm that the pressures are appropriate.
Hope this helps.
Old Mar 5, 2022 | 05:50 PM
TheMoke's Avatar
I have stock 22s and don’t find them too noisy or the ride too harsh. They are better than the 20s of my old RRS. The tire wall depth is slightly larger on the 22s. I would also check tire pressure.
Old Mar 5, 2022 | 07:00 PM
4wd High
Hope this helps.
I ran on 285/45/22 with tyre pressure set to light load. Will go to have an alignment done on monday.
LR3 Bros
Mar 3, 2022 06:13 AM
peterboz
Range Rover Evoque
Sep 4, 2018 02:41 PM
fellipe
Nov 29, 2015 03:53 PM
aaron22
Jul 4, 2015 09:15 PM
Mark G
Dec 4, 2007 01:01 AM
