Grinding noise on left front wheel area on sloppy roads?
Old Nov 29, 2015 | 05:54 AM
fellipe's Avatar
Default Grinding noise on left front wheel area on sloppy roads?
Hi guys,
noticed a grinding noise on left front wheel area that happens only when going on a sloppy road... some facts that may help you identify it:
- it's acceleration independent
- doesn't stop if I press the brakes
- doesn't happen on smooth roads/tarmac
any clues?
thanks
Old Nov 29, 2015 | 09:09 AM
BackInA88's Avatar
Are you sure it's not your Traction Control kicking in?
Old Nov 29, 2015 | 09:12 AM
fellipe's Avatar
Pretty sure it's not the tc... Picture a cobblestone road. That's the kind of road that triggers this noise... Pretty noticeable on slow speeds..
Old Nov 29, 2015 | 01:22 PM
chubbs878's Avatar
I would definitely take the wheel off and start searching for anything visually or physically suspect starting with pads, caliper, wheel speed sensor, hub and CV joint,while waiting for advice. You don't have any cluster lights or codes that may be related?
Old Nov 29, 2015 | 03:53 PM
DiscoCam's Avatar
Sounds like a CV joint about to fail.
deepCsmitty
Oct 4, 2012 07:59 PM
spicer
May 6, 2012 11:18 AM
bagocheetohs
May 10, 2011 08:17 PM
ZMayo85
May 3, 2007 12:00 AM
84 GRANDSPORT
Feb 12, 2007 07:47 PM
