What’s the most annoying rattle you’ve found (and fix?)
Old Apr 8, 2021 | 06:36 PM
2020Defend3r's Avatar
Default What’s the most annoying rattle you’ve found (and fix?)
Guys, I’m just curious what rattles and or creaks you’ve found that are consistent across others Defenders. I’ll start, a rattle on larger bumps on right top near that thin small window thing (safari window?). That’s it.
Old Apr 8, 2021 | 11:40 PM
TheMoke's Avatar
I won’t be able to contribute to this thread properly until my defender arrives sometime end of June. Rest assured my ears are highly tuned to car trim rattles. Many years ago my hard driven company car was in for repairs and I had a rental car for a few weeks while it was being fixed. The rental had an annoying buzzing noise coming from one of the rear retractable seatbelt mechanisms. Rather than just ignoring it or simply swapping the car for another rental, being the idiot I am, I decided to fix it myself. Needless to say, while dismantling it, the tightly coiled spring inside forced its way out, hit me in the face and ended up completely reverse-coiled and knotted up on the floor along with a bunch of other pieces. I spent the entire day trying to wind the spring back in its housing and eventually succeeded. The look my wife gave me when she realized what I had done and what I’ve was trying to fix said it all. Shockingly, the rattle went away after I managed to put it back together. My only worry was the poor soul that would one day come to relying on that belt to do its life saving job. I still haven’t learnt my lesson and so will go to any length to track down and fix squeaks and rattles. I even have a stethoscope to help. Very sad.
Old Apr 9, 2021 | 01:02 PM
sblvro's Avatar
No rattle. Solidly quiet!
Old Apr 9, 2021 | 05:16 PM
Defendit..'s Avatar
Everything that rattles, You still own.....
Old Apr 9, 2021 | 08:34 PM
BaconL's Avatar
No rattles yet but I noticed my front right speaker sound like it's blown or have a tiny rip. There's this annoying buzz sound whenever it hit some low freq.
Old Apr 10, 2021 | 02:43 PM
Gator42's Avatar
The rig is so quiet and tight a little rattle goes a long way...A-pillar number one. The window molding a distant number two. There's also one coming from the cargo area somewhere but it might be just the fabric cover flexing a bit.
Old Apr 13, 2021 | 02:38 PM
Everyday_110's Avatar
8th Gear
The window molding/weatherstripping is the most annoying to me. With the doors open, I pulled back the molding and used clear silicone to better adhere it to the door frames. Worked like a charm and was $2.99 in materials. Cheapest Land Rover fix yet.
Old Apr 13, 2021 | 07:29 PM
I noticed the cargo area as well. It’s faint and I think it’s coming from the rear hatch that covers the concealed cargo area beneath the floor.
Old Apr 13, 2021 | 08:01 PM
Tasman Blues's Avatar
7th Gear
I have this same exact rattle/creak except mine was on the left side. I've just about completely silenced it (95% gone) by shoving a business card in between the window trim and the insulation behind the headliner. I'll have the dealer look at it at some point but for now the card "fix" is working fine!
Otherwise, I have intermittent noise from the windshield / passenger A-pillar at higher speeds and crosswinds. It is somewhat sporadic and not that bad - I may mention it but it's not worth pulling things apart at the moment. Every now and then I hear very faint noises from the b-pillar area (probably the window trim noise I've seen mentioned) but it is even more sporadic and extremely faint. If it gets worse I'll try the silicone fix.
That's it. Frankly, 90% of the time the car is rock solid and quiet. I'm usually pretty maniacal about these types of things and so far I'm pretty pleased (although the rear window rattle was pretty bad on bumpy roads prior to the business card repair!).
Old Apr 14, 2021 | 08:45 AM
dsallean's Avatar
I had the same speaker sound and the dealership fixed it last week. Said the speaker bolts weren't tightened correctly.
