Why does my climate control fan run occasionally when parked?
I know this is a silly thread, I've searched off and on for years for an answer on this one. Occasionally when I walk out to my car after it's been parked the circulating fan inside will be running almost full blast. It's done the same thing while camping sometimes and every now and then I'll get a low-battery warning (which makes since if it's using power for the fan for prolonged periods of time). I've tried running through the various menus to see if this is something that I can shut off, and my dealer isn't much of a help. Looking for any input!
That's odd / and I don't think it should be happening. Has not on mine.
Do you have a D90? Or a 110? I ask because the early 90's had a problem with a seam not being sealed in the A-pillars, which causes water to fill up under the plastic floors, and this sounds like the type of thing that would happen with water ingress... eek eek.
