Yakima RTL600
Old Jul 18, 2023 | 06:43 PM
boranup's Avatar
Default Yakima RTL600
Has anyone successfully installed the Yakima RTL600 quick release roof racks to their defenders with the factory installed roof rails? Im looking for a rack I can remove quickly by myself to ensure height levels at carparks when Im not carrying surfboards on the roof.
R474 RLT600 Removable Track issue12.indd (rhinorack.com)
Cheers
Lance
Old Jul 18, 2023 | 07:51 PM
SilverSFR's Avatar
How are those roof bars quick release. They look to be the standard type roof bars that bolt down. The same type as the oem Land Rover ones or that standard knock off ones you can buy on Amazon/eBay.
Old Jul 18, 2023 | 08:24 PM
boranup's Avatar
Take the cover off - squeeze the tabs and they pop off - used them on a ford ranger and they were excellent
Old Jul 18, 2023 | 10:19 PM
SilverSFR's Avatar
Interesting and I should of scrolled and continued reading. Great idea really.
Old Jul 18, 2023 | 11:00 PM
CEHansen's Avatar
You mean like this?
I had to fabricate my own plynths and clamps to make it work. The front and rear plynths are tapered to get all three bars on the same plane. The clamps under each tower are one-peice with two threaded screw holes to match the footprint of the tower base. You will definitely want an air dam with this setup because it can really howl. Here’s mine.
Hope this helps.
LR disco 5
Jan 17, 2022 10:05 PM
gwelland
Mar 3, 2021 08:52 AM
overover02
May 21, 2014 09:17 PM
Batesy
Jul 16, 2010 06:16 AM
lholho
LR2
Oct 5, 2008 02:10 PM
