Winter Romp 2019
Old Feb 23, 2019 | 01:59 PM
  #31
stillruns's Avatar
Not mine. Pulled from the World Wide Web:
Another:
It appears that you need 2+ inches of lift and good tires to navigate the trails. The white D2 @5:40 has a good setup. Hits the tree lol.
Old Feb 23, 2019 | 09:20 PM
  #32
There was a white D1 no lift with chains that did fantastic. Owner was super friendly as well
Old Feb 23, 2019 | 10:03 PM
  #33
stillruns's Avatar
Would a simple air locker have prevented some of these folks from getting stuck or was is just super slick and winching is inevitable.
Old Feb 24, 2019 | 05:28 AM
  #34
Depends on the situation. A locker was a handicap in quite a few sections of trail with the trail slick as heck and off camber. When the locker engaged it just slide the truck right off into the trees. This made the winch the only ootopt for going forward. One of the best I saw for getting around was a 90 with duratrac tires and only cdl.
Old Feb 26, 2019 | 12:47 AM
  #35
Dsport's Avatar
Armyrover, your truck looks great! What size tires do you have on there? Airbags or spring conversion?
Old Feb 26, 2019 | 06:37 AM
  #36
The Range Rover Sport is on 32.5" and air suspension.
The LR3 in the picture is on 32" and air suspension.
I am on 32.5" and coil conversion
Old Feb 26, 2019 | 11:43 AM
  #37
Dsport's Avatar
haha my bad 😅 , figured that was your LR. But it sounds like your setup is even better!
Old Feb 26, 2019 | 11:52 AM
  #38
Similar trucks so it's easy to confuse them
Old Mar 2, 2019 | 05:07 AM
  #39
The Deputy's Avatar
Finally had a chance to watch the videos, good stuff. And although it looks like fun and temps didn't look to horrible...l'd still be hard pressed to play in the snow anymore.
​​​​​​​ Brian.
Old Mar 2, 2019 | 07:27 AM
  #40
The weather aside from the bit of rain on Friday was phenomenal. You should make the trek at least once if your a Rover owner. Waterville is a must experience.
Friday Night Disco
ROAMING WITH FRIENDS
44
Oct 28, 2022 02:59 AM
Best4x4
15
Oct 16, 2018 01:45 PM
ArmyRover
17
Apr 10, 2018 05:46 AM
ArmyRover
15
Dec 18, 2017 06:04 PM
ArmyRover
17
Sep 5, 2017 08:53 PM
