Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
04D2 speakers
Old Nov 23, 2011 | 07:41 AM
msggunny's Avatar
Default 04D2 speakers
Looking to upgrade the stereo in the D2. Looking at the speakers in the door cards they seem a bit "special".
Are there any direct fit replacements? Crutchfield said there was no direct fit replacements.
For those of you who have upgraded the door speakers, what did you use and how did you make them fit?
Thanks.
Old Sep 25, 2012 | 12:11 AM
bootzilla's Avatar
Interested in the answer to this, too.
Old Sep 25, 2012 | 08:55 AM
04duxlr's Avatar
I have an 04 DII witrh the premium sound system. I installed Pioneer 6 1/2 inch 2-way speakers that I picked up online for $28 a pair. They sound awesome with the stock amp.
Amazon.com: Pioneer TS-G1643R 6.5-Inch 2-Way Speakers (Pair): Car Electronics Amazon.com: Pioneer TS-G1643R 6.5-Inch 2-Way Speakers (Pair): Car Electronics
Old Sep 25, 2012 | 09:02 AM
hilltoppersx's Avatar
i can't speak for the pioneer above but if he says it fits i guess it does. the problem with the replacement speakers in the D2 doors is the space for the magnet of the speaker is so shallow that most 6 1/2" speakers don't fit because of depth restrictions.
Old Sep 25, 2012 | 09:10 AM
04duxlr's Avatar
The Pioneers are pretty shallow. I put them in both front and rear doors. I just clipped the wires to the tweeters. You can pop off the speaker grilles ansd install them from the front without pulling the panel. Two of the screw holes line up, then you need to bend down a portion of the rim of the speaker to clamp it at the other locations. These speakers have a very low frquency response so they really fill out the low end. I also swapped out the rear door subs for a pair of Kickers powered by a seperate amp which helps as well.
Old Sep 25, 2012 | 11:13 AM
thanks for the follow up and specifics. Might have to pick up a set myself.
Old Sep 26, 2012 | 12:50 AM
bootzilla's Avatar
Ah - that answers the next question I was going to ask.
The Amazon page says those Pioneers are 1 5/8 which is really thin - excellent find.
For the subs - did you just pull the feed that was going to the factor amp? I need to do something about those rear door speakers - I can hear low frequencies coming from them when I put my ear against the grill, but there is almost no volume at all...
Old Sep 26, 2012 | 09:53 AM
04duxlr's Avatar
I believe the factory amp has a built in crossover. My DII came with an aftermarket Alpine head unit, so I just used the sub pre-out to feed another amp. You should be able to take the factory sub feeds outof the stock amp and use a line-level converter to hook up an aftermarket amp. You may be happy with the factory subs with more power.
msggunny
May 31, 2013 03:48 PM
riches
Nov 4, 2005 12:34 PM
Lebowski87
Aug 15, 2005 04:12 PM
slamwhit
Jun 18, 2005 02:13 AM
Shabber
Mar 28, 2005 11:59 PM
