Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
07 LR3 Car Audio Build Thread
Old Apr 20, 2025 | 01:46 PM
  #21
The_OGCJR's Avatar
Default Finally so more progress
After a crazy couple months and the SCARR rally I was able to get back on this…had to add some wood to the bottom near the rear so I could bolt the rack down
then added some supports because I need to be able to put weight on top
Old Apr 20, 2025 | 01:53 PM
  #22
The_OGCJR's Avatar
Did some cad
Old Apr 23, 2025 | 09:18 AM
  #23
The_OGCJR's Avatar
Got it looking good but waiting on a hinge and some other stuff
now getting back on the tailgate sub
I dremel off the end caps from the oem panel and they half to fit over the plywood flush. So I got that done.
but also, in the last pic…you see there is a piece that has to be trimmed off
Old May 9, 2025 | 08:47 AM
  #24
The_OGCJR's Avatar
Ok to make the rear tailgate top trim sit flush, I had to cut out the center screw mounts from the trim…but look how pretty it fits…
Old May 9, 2025 | 08:49 AM
  #25
The_OGCJR's Avatar
I’ve taken this amp rack out several times in this process and will probably have to again but for now, let’s start wiring it up to get some tuning done etc
Old May 30, 2025 | 09:36 AM
  #26
The_OGCJR's Avatar
Update
got everything together and started the tune
For beginners, I don’t recommend the Minidsp. It’s got quite a bit of learning curve and the Dirac live is hard to calibrate unless you have a dead silent area to use
I found that if you are bypassing the factory amp like I did, you don’t need the Most adapter. I can explain this more if someone asks me too. I’m going to edit the first post to update.
Things I still have to do:
pretty up the sub mounting and fix rattles lol
add my other sub box and do a tune for those
find oem style grills for the front speakers
DiscoCam
Mar 5, 2016 10:23 AM
Brian Taylor
Nov 6, 2015 02:28 PM
hobbsrover
Aug 22, 2015 07:23 PM
mchang
Dec 14, 2012 01:19 AM
senortetas
Jan 5, 2007 07:07 PM
