Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
radio install help
Old Oct 28, 2008 | 02:54 PM
s928s's Avatar
Default radio install help
I am in the process of replacing the factory Harmon headunit with a dvd based unit using the harmon amp if i can. I have the propper conncetors for the 2 main inputs. have all 4 channels wired to the line connections of the new headunit to the harmon amp. I believe the amp trigger wire is #5 at
connector c0098, connected to amp remote wire to the new headunit. And i still have now sound. ANY hints ???????
I have searched through post after post for this issue. I scanned over the factory wiring inputs/outputs to the BECM and they do not appear to control radio or amp function.
Is this possible, am i missing something to trigger the amp ??
i am working on a 1999 LRII W/HARMON PREMIUM AUDIO.
THanks in advance, DAVID
robdis96
Feb 22, 2013 07:07 PM
sickws6
Jan 8, 2012 12:48 AM
indy11bravo
Feb 28, 2010 05:53 PM
thomas22
Jun 15, 2009 10:38 AM
95DiscoSE7bullitt
Mar 2, 2006 03:54 AM
