2002 - Goldie Build
Old Dec 8, 2019 | 08:02 PM
They are on the bulky side and are definitely a workout
Old Dec 11, 2019 | 12:55 AM
Richard Gallant's Avatar
@soarvet Yea mine leaks a bit, the suggestion I was given was a big floor jack and a 2x4 frame to keep it in place. Transmission jack might be easier but no one rents them around here
Old Dec 26, 2019 | 09:13 PM
soarvet's Avatar
Well, things have been progressing. I have the new transfer case installed. It wasn’t as bad as I thought getting it in. Took some finagling and patience and eventually succumbed to my banging, twisting, and cursing. Got everything wired up and tested the CDL. Got a nice light in the top left of my instrument panel, so everything is good. With that done, I tackled the lift. The lift went in without a hitch. Since I went with the 3 inch lift I figured it would be wise to install some new extended steel braided brake lines. New rims and tires and she’s sittin’ pretty. Almost thought I wasn’t gonna get it out the garage, but I got her out barely.
I actually had to cut some of the bumper as I was getting some pretty good rubbing at full turn. Next on the list is new bumpers I think and rock sliders. Here’s a few pictures from today after I took her on a test drive to test out the CDL and make sure I could go from Hi to Low range and back.
Old Jan 7, 2020 | 01:14 AM
danicollins's Avatar
Impressive build!
Old May 6, 2020 | 08:13 PM
soarvet's Avatar
Been a minute since I last posted. Been hopping back and forth between projects. I've had a pretty decent oil leak that covers the bottom of my engine and drivers side chassis. I tracked it down to the front crank seal. Finally got around to changing the seal out. Had a couple grooves in the Harmonic Balancer where it rides in the seal.
Installed a jiffy sleeve and got it put back together. Looks like it fixed the oil issue. Went on a short 5 mile test drive, got home and crawled under the Disco. It was dry so time will tell. I'd like to get a couple hundred miles on to really see if it fixed the leaking I was experiencing.
On another note: I got front and rear bumpers installed:
rear bumper installed.
Lucky 8 front bumper with Smittybilt 10k winch
Old May 8, 2020 | 04:45 AM
The Deputy's Avatar
Looking good!
Richard Gallant
Jun 4, 2019 05:20 AM
ciglesias
Mar 11, 2017 10:38 AM
adwarren78
May 19, 2015 09:15 PM
NiteTrain
Sep 30, 2010 08:06 AM
krazzz
16
Nov 17, 2009 11:33 AM
