The Green bastard
Old Jan 30, 2021 | 06:17 AM
  #221
Fastercat's Avatar
My front main seal has started leaking, what’s the deal on sleeping the crank pulley? Could I just try to polish it and try a new seal?
Old Jan 30, 2021 | 09:23 AM
  #222
The Deputy's Avatar
Remove harmonic balancer, look closely at the depth of the seal in front cover. Sometimes it possible to install the seal a little deeper or not as far, to avoid seal working the same area. As long as the harmonic balancer is not grooved heavily, feeling them with your finger nail, you should be able to clean it up with crocus cloth. Seal gets old and brittle, causing it not to grasp balancer well...new one will make all the difference in the world. Did on the three Dll's l've done...not a drop.
Old Jan 30, 2021 | 11:46 AM
  #223
Fastercat's Avatar
When I rebuilt the motor I did install a new one onto the front cover while it was off, I just pushed it to the back, the pulley definitely had shiny spots where it spun against the old seal, I didn’t think was that bad, I’ll have to pull it out and check it again. What’s the best way to pull old seal? Screw into it and yank? Or dig it out?
Old Jan 30, 2021 | 05:26 PM
  #224
The Deputy's Avatar
Just dig it out carefully, since the surface it rides against is out of the way (harmonic balancer).
Odd that a new seal would leak this quickly, check for damage on seal bore in housing, maybe add a little sealant if need be.
Old Jan 31, 2021 | 08:07 PM
  #225
Shiftonthefly1's Avatar
I just binged this entire build. Love it. That's my favorite color Discovery.
Old Feb 28, 2021 | 06:47 AM
  #226
Fastercat's Avatar
Condition of my headers after there first winter
Found my slow coolant leak. That was a brand new britpart hose assembly I used when I installed the motor last summer.
I guess for using a spray can paint there not horrible considering how much salt hey use on the roads around here
We had a nice day out yesterday here, snow is melting, so I checked Under the hood to plan some upcoming maintenance. Have both coils, new plugs and wires, upper intake gasket, and front main seal on there way. Will probably do the thermostat mod as well.
Old Mar 28, 2021 | 04:34 PM
  #227
Fastercat's Avatar
I haven’t updated in a while but the new tuneup has been great, my mileage is way way better. Up from 10.8 to 12.9 mpg. I just pulled my winch and went through it a bit today, the compressor on it has refused to engage. I’ll spend more time on when the weather gets a little better.
Old Apr 10, 2021 | 09:21 PM
  #228
Fastercat's Avatar
Finally changed the front main seal. While I was in there I noticed a power steering hose seeping. Ordering more parts. Lol. Never ends
Old Apr 17, 2021 | 07:31 PM
  #229
Fastercat's Avatar
New steering lines put in today, thinking I may have to order a new pump now. Lol. It was so messy I couldn’t tell if it was the pump or the hose. This was a used pump I put in last year or maybe 2 ago.
Old Jul 27, 2021 | 02:21 PM
  #230
Fastercat's Avatar
Well the used pump has been fine, hardly any steering leaks now, front main has been good since I changed it out, now about to change the cowling for a non cracked one and fix my wipers as well
