Her name is Majesty
Old Apr 29, 2018 | 01:20 PM
  #41
Saturnine's Avatar
Looking good!
Old May 2, 2018 | 06:12 PM
  #42
TRIARII's Avatar
Finally got the washer fluid system back together (hopefully). As stated previously "EVERY" washer fluid hose connector was disconnected; front and rear. Replaced wiper blades and wiper arms front and rear (D1 style arms). Also replaced the rear wiper arm motor assembly and cargo door LR badge.
Trying to figure out why one of the license plate light bulbs keeps turning off. Give it a little knock and it comes back on. Bulbs are both new.
Swapped out the damaged wheel/tire but broke a stud in the process.... fortunately I have 2 brand new still in box wheel hub assemblies at my disposal.
Replaced both O-rings on the oil filter adapter assembly and changed the filter but its still leaking oil.
Old May 2, 2018 | 06:17 PM
  #43
TRIARII's Avatar
Old May 3, 2018 | 03:20 AM
  #44
The Deputy's Avatar
There's a couple plugs on the oil pump housing, where oil cooler would attach on older models...one above oil filter and one below...check those. I believe there is an o-ring or something that needs attention usually.
Brian.
Old May 4, 2018 | 09:41 PM
  #45
TRIARII's Avatar
This dam forum is deleting my pictures!
Old May 5, 2018 | 04:54 AM
  #46
The Deputy's Avatar
I'm seeing pictures...in all of your older posts.
Old May 6, 2018 | 01:56 PM
  #47
TRIARII's Avatar
I have them uploaded in order from day 1 to present. Some of the pics are not appearing at all despite the coding being present when I go into edit the post. Pics of the radiator and pics from day 1 disappeared. Ive been having issues with this forum for afew weeks now and admin cant be bothered as usual. Ill try to log in from my pc and re-upload. Also chrome for android is experiencing a bug that crashes everytime you try uploading pictures. Pain in the ***.
Old May 6, 2018 | 03:42 PM
  #48
TRIARII's Avatar
Today I replaced the rear wheel hubs and 0-rings and swapped over the pads and rotors from the old truck. Luckily I have afew extra lug nuts. Also installed trailer wiring harness.
Pulled pads and rotors from the parts truck
Driver side
Driver side
Drivers side
Drivers side
Passenger side
Passenger side
Old May 6, 2018 | 05:46 PM
  #49
Saturnine's Avatar
MagPie has the trailer wiring but it is a complete sh-t show of wiring behind the passenger taillight. Yours looks all purty and clean!
Nice work!
Old May 12, 2018 | 06:03 PM
  #50
TRIARII's Avatar
Default Frame is solid
