Life with a Free 2000 Discovery II
Old Dec 13, 2014 | 06:46 PM
  #81
ls1morethanyou's Avatar
fan clutch is easier done when you pull back on the tensioner pulley, then use an adjustable wrench and hit it with a small sledge. takes me 3-4 hits normally.
Old Dec 13, 2014 | 11:46 PM
  #82
cornbreadj's Avatar
What suburb of Chicago are you from
I lived in lemont about 8 years ago
Old Dec 14, 2014 | 03:03 AM
  #83
McHenry
Old Dec 14, 2014 | 07:27 AM
  #84
potxoli's Avatar
Hi, If you look at the thread I posted above you will find a method with vise grips to prevent the fan from moving. Worked for me. See here: Land Rover Discovery Fan Clutch Removal | Another Tech Blog
Another way, Autozone rents a fan clutch tool for ford (or sells it for $25). That tool can be used to capture the bolts on the fan clutch to prevent it from moving. It is not perfect, but the end of the tool has a square opening that fits over the bolts and can help hold the the fan while releasing the nut.
hope this helps.
Old Dec 15, 2014 | 02:16 PM
  #85
Thanks for the link I'll see about picking up another set of vice grips that are a bit larger
Old Dec 15, 2014 | 03:23 PM
  #86
dusty1's Avatar
come on Nancy, you can do it!
Old Dec 15, 2014 | 05:18 PM
  #87
Bite me Dusty
Old Dec 21, 2014 | 11:17 AM
  #88
Well got some new to me tires for Xmas 265/65/18 bridgestone dueler ATs.
Now its back to trying to remove the stupid fan clutch.
Old Dec 21, 2014 | 01:28 PM
  #89
The stupid fan is off, it was a casualty along with the tensioner pulley.
Old Dec 21, 2014 | 02:57 PM
  #90
dusty1's Avatar
