my 98 disco1
Old Nov 2, 2013 | 07:00 PM
  #161
TOM R's Avatar
Still touching ground stock tires rear sway still on
Old Nov 2, 2013 | 07:05 PM
  #162
TOM R's Avatar
Stuck not enough forward momentum other side drops off same as this
Old Nov 3, 2013 | 12:31 AM
  #163
nuclearw's Avatar
Hey I recognize that black dot!
Truck looks good keep up the work
Old Dec 11, 2013 | 03:24 PM
  #164
TOM R's Avatar
original stock tires and suspension
goodbye yuppie wagon hello rover now just need the roof rack
New 245/75/16 E rated a/t tires on the 2" ome hd lift
Old Dec 11, 2013 | 03:27 PM
  #165
TOM R's Avatar
245 spare on steel rim on door for those that want to see the clearance under tire
Old Dec 11, 2013 | 04:10 PM
  #166
olywa's Avatar
Originally Posted by TOM R
Here are the city lights with white led cheap on eBay also fit marker lights
can you give some details on the lights? What did you search on eBay.
Old Dec 11, 2013 | 04:20 PM
  #167
TOM R's Avatar
cut and paste this in search on ebay
T10 Wedge 5-SMD 5050 LED Light Bulbs
they are led license plate bulbs
with led if you install and they do not light remove rotate 180* and reinstall power has to go in a certain direction unlike regular bulbs
Old Dec 12, 2013 | 03:48 AM
  #168
olywa's Avatar
You use those light as head lights?
Old Dec 12, 2013 | 06:18 AM
  #169
TOM R's Avatar
No they are the city lights/parking lights
Old Jan 15, 2014 | 05:13 PM
  #170
TOM R's Avatar
Stuck with a strange intermittant high idle after having the tps shorter by a bad fuel pressure sensor, was reffered to a shop in north jersey by another member so gonna try a ecm reset
Think the shop said they have all makes? Scanner will this also program my remote?
