my 98 disco1
Old 05-08-2013, 08:55 PM
TOM R's Avatar
end pic hanging to dry
  #52
Old 05-11-2013, 09:00 PM
TOM R's Avatar
got the rad back today, had 5 bad tubes that were not able to be rodded all at the top and the bottom was clogged no big surprise, he says the rad will last a little while but the fins are disintegrating and recommends buying an aluminum one in a few years
got it installed and idles at 185* we will see what happens when it gets hot out
the one I removed from my rover today looked externally waay worse then the donor I had rodded I was considering having it done also but think I may hit the scrap bin
also got the upper trans cooler line from the rad to the remote cooler replaced since it was crazy routed
  #53
Old 05-12-2013, 07:08 PM
TOM R's Avatar
went trail riding at a friends property today and found a few things out
1) my hf winch setup with the wireless remote works awesome very happy with this
2)running boards I really like and need for the boy and wife need to go to easy to get hung up on
3)my nice continental contitrac tires could be a little more aggressive for mud but work great for trails so I am up in the air with the tire tread since I am mainly on road and the drive great on road and wear long
4)the shocks and springs I installed work great I would like to be a little higher but not much cause then all the high branches would be whacking the body so I am up in the air on the suspension size
5) have to get safari rack
6) cdl and low worked great no idea how you trail ride without the cdl
7) fix a/c
8) be extremely careful winching with wife behind the wheel
9) think I get plenty of articulation with sway bars on
  #54
Old 05-13-2013, 03:27 PM
TOM R's Avatar
  #55
Old 05-13-2013, 09:39 PM
zigzag3141's Avatar
I see you had the factory brush guard prior to your mods with the Sahara grill, discrete mount and new front bumper....
I have the same discrete winch mount that I havent installed yet. Question - is it possible to use the discrete mount with the factory brush guard? I can see where it mounts to the frame at the same place as the stock bumper & brush guard. Can I use all 3 (ie, stock bumper, stock brush guard, & discrete winch mount) if I get some longer bolts???
  #56
Old 05-13-2013, 10:05 PM
TOM R's Avatar
I did, but had to cut out the lower center crossbar for the brush guard I made my hidden bracket so it may sit lower then yours, look through all the pics
I did drill the holes out in the bumper and bg to 1/2" the holes in the frame are 1/2" but you need to ream them with a 1/2" bit to be sure
  #57
Old 05-14-2013, 12:31 PM
TOM R's Avatar
wohoo my snorkel showed up today, brand new $187 shipped from Malaysia (ebay)
  #58
Old 05-14-2013, 02:14 PM
fishEH's Avatar
Wow, got a pic? What make is it?
  #59
Old 05-14-2013, 03:28 PM
CUpgt's Avatar
  #60
Old 05-14-2013, 04:45 PM
TOM R's Avatar
yup that's it sorry $185 shipped he only gets in a few at a time had to wait a while to order it, lots cheaper then the 4-500 everyone else wants, comes with fender template but no install instruction sheet
install thread
https://landroverforums.com/forum/di...-instal-59380/
Quick Reply: my 98 disco1
