Operation Magpie.
Old Apr 20, 2018 | 11:42 PM
  #101
Saturnine's Avatar
Got the heads, they look incredible -- no pics yet! They ended up being resurfaced .014, so last time these heads can be machined but I'm not concerned honestly. Supposed to be snowy/rainy tomorrow so keeping my fingers crossed i can actually start putting things back together. Just been doing a ton of cleaning both in the bay and parts that came off.
Old Apr 21, 2018 | 03:29 PM
  #102
Saturnine's Avatar
Well my fingers officially are tired of scrubbing off all the sh-t on this engine. Replaced all the o-rings on the injectors, the old ones were in fairly good knick, none were cracked but all were on the brittle side.
Having to clean all these bits in the kitchen sink sucks *****.
Old Apr 22, 2018 | 07:29 AM
  #103
Saturnine's Avatar
Welp, its 630am and today is the day. No snow today, supposed to be in the 60's so its game on for getting everything back together.. Or at least most of it.
I'm so ready to be done with doing this job!
Old Apr 22, 2018 | 12:53 PM
  #104
ihscouts's Avatar
Having .014 removed makes a statement about the warpage, now they're square.
Old Apr 22, 2018 | 05:20 PM
  #105
Saturnine's Avatar
Indeed they were fairly fubard..
In other news, this happened. Brand spanking new, did the initial 15lb with the torque wrench and the first 90 degree rotation. After 30 mins, started to do the 2nd 90 degrees, got maybe 30 degrees in when i heard a really loud pop and then the wrench went loose. **** **** **** **** **** was the only thing going through my mind -- backed it out slowly with a wrench and got it out.. Got lucky on this one for sure.. Good thing it was the most accessible bolt on the passenger side, closest to the t-stat. Gonna get a new bolt tomorrow along with some gaskets for the exhaust which apparently doesn't come with the HG kit from Lucky8.
Old Apr 22, 2018 | 06:48 PM
  #106
The Deputy's Avatar
Ouch. Can't remember right off hand, but aren't there three different size bolts, three long, two medium for under valve cover and five shorter ones for along exhaust edge. Bet your heart sunk a few feet, when that baby snapped.
Brian.
Old Apr 22, 2018 | 09:26 PM
  #107
Saturnine's Avatar
Yeah, it certainly did. Everything is ok though. There are actually 2 bolt types -- middle 3 near lower IM are longer, the other 7 are shorter bolts. This one is a shorter one.
Yay pics.
Decided this would be a good time to re-wrap the engine harnesses with a silicon tape, so easy to use and better than that crappy plastic non-sense.
Old Apr 23, 2018 | 06:12 PM
  #108
Saturnine's Avatar
Got a lot done today! Didn't really take any pics but I'll snag some tomorrow.
Got the lower intake manifold installed, valve covers, CP+wires and most of the SAI crap. Just need to put the front of the motor back together and slap on the upper intake and should be good to go. Ran out to a local rover shop to pick up a new head bolt and exhaust manifold --> DP gaskets because the Lucky8 kit didn't come with them. Bugger. Speaking of not included -- the upper hard pipe gasket Gonna run to a local parts store and pick up something because.. its just an o-ring, can't be that difficult to find one that'll work... right?
Everything went ok but i'll be honest.. the valve covers were annoying. I had picked up a can of that spray tac crap that the AB guys used in the yewtube vid and I wasn't really happy with how it worked. It was tacky but it sure as hell didn't really hold the gasket on very well (all surfaces were clean) so i had to futz with it a number of times to make sure that it seated properly.
Just need to get a jug of coolant and change the oil.. Also picked up a transmission filter / service kit but i'll probably do that in a week or so.
Yay.
Old Apr 23, 2018 | 08:04 PM
  #109
ihscouts's Avatar
Almost there, you'll be glad you did it - not that you had much choice. Now you'll be able to dole out advice like a chilled out been there done that vet.
Old Apr 23, 2018 | 08:42 PM
  #110
Saturnine's Avatar
Maybe I won't be glad but my wallet certainly will be
No really though, I feel good doing this type of stuff.. assuming it works
