Operation Magpie.
Old Apr 25, 2018 | 11:55 AM
  #111
Psycho_Taco's Avatar
Originally Posted by Saturnine
Everything went ok but i'll be honest.. the valve covers were annoying. I had picked up a can of that spray tac crap that the AB guys used in the yewtube vid and I wasn't really happy with how it worked. It was tacky but it sure as hell didn't really hold the gasket on very well (all surfaces were clean) so i had to futz with it a number of times to make sure that it seated properly.
A trick my buddy taught me was to put drill bits in each bolt hole. You can slip the gasket over them, line up the cover, and then replace the bits with the bolts one at a time. It helped me when trying to get those darn gaskets lined up properly.
Hopefully Magpie will run smoothly for you after all of this!
Old Apr 25, 2018 | 11:37 PM
  #112
razorkill12's Avatar
Looking good! I did one head today..put valve seals in, cleaned and checked with straight edge..ready to go back on. . Hopefully will get other head ready tomorrow to put back on and get back on the road..
Old Apr 26, 2018 | 08:06 AM
  #113
Saturnine's Avatar
Thanks for the tips!
Everything is on hold at the moment because of the L8 HG not coming with the upper coolant hard pipe O-ring. I think I can probably just goto the local parts store and get something that’ll work — maybe tomorrow!
Im to lazy to look right now but these engines are Buick 215’s, right?
Old Apr 26, 2018 | 08:10 AM
  #114
Sixpack577's Avatar
The lower intake and o-ring won't be on the Buick engine.
  #115
Saturnine's Avatar
Well, poo on a stick.
Old Apr 26, 2018 | 08:11 AM
  #116
Sixpack577's Avatar
If you need something to do, you can finish putting my engine together and get it back in the truck for me.
Thanks!
Old Apr 26, 2018 | 10:07 AM
  #117
Saturnine's Avatar
Lots of beer and pizza plus a plane ticket and I’m there
Old Apr 26, 2018 | 11:47 AM
  #118
Sixpack577's Avatar
You had me, up until the plane ticket, lol
Old Apr 26, 2018 | 11:53 AM
  #119
ihscouts's Avatar
Usually decent hardware stores have O-rings, just take with and compare.
Old Apr 26, 2018 | 12:18 PM
  #120
Saturnine's Avatar
Cheap skate
