Operation Magpie.
Old May 3, 2018 | 07:27 AM
  #151
Saturnine's Avatar
Confirmed t-stat is dead. Drove 1.5 miles, parked right at 230 degrees. Parked and popped hood — lower hose coming off of rad to t-stat was stone dead cold while the others were hot and pressurized!
Old May 3, 2018 | 07:42 AM
  #152
Sixpack577's Avatar
That sucks, but good news and a simple fix!
Old May 3, 2018 | 07:49 AM
  #153
Saturnine's Avatar
Aye. Finally a light at the end of the tunnel!
Old May 3, 2018 | 10:17 AM
  #154
Jeff Blake's Avatar
Told ya so!
Was it a genuine grey 180 stat? If so, that counts a few too many failures of brand new stats, including mine. I'm going to try to the Britpart black one on the next swap.
Old May 3, 2018 | 11:09 AM
  #155
The Deputy's Avatar
That's why having a Infrared IR Thermometer gun is so important in diagnostics. It can answer questions pretty quickly.
Brian.
Old May 3, 2018 | 05:02 PM
  #156
Saturnine's Avatar
Aye, they are. I find mine more useful as a cat toy though
Called Lucky8, and things have been sorted. Have to buy a new t-stat, but after the claim to manufacture goes through I’ll get reembursed. Need to provide a picture and a brief explanation and that’s it.
Maybe ths $60 for a new t-stat would be better spent on the inline setup?
Old May 3, 2018 | 08:04 PM
  #157
Jeff Blake's Avatar
You use that emoji a lot
Old May 3, 2018 | 08:07 PM
  #158
Saturnine's Avatar
It sums up a lot of things about MagPie.
....and my sanity
Old May 3, 2018 | 10:47 PM
  #159
Saturnine's Avatar
Hmm.. Noticed the windshield wipers were acting all weird. Did some digging, apparently the contacts in the column can get all mucked up.
Also gotta bleed the brakes -- pedal feel is good initially then it gets rock hard and you basically have to stand on the damn thing to get the truck to a full stop.
The list goes on and on..
Speaking of a list, this is what i need to finish:
Tranny filter / fluid
Diff fluid
Bleed brakes
Fix headliner
Redo rear bumper and add some more metal to it
Weld muffler hole
Install bull guard in front
Install USB plug in cig lighter
Get new windshiled
New wiper blades
Check alignment
SMOG
Fix SRS light
Ugh. Writing all that down was depressing.
Old May 4, 2018 | 01:56 PM
  #160
Saturnine's Avatar
Hot digity, got the SRS light fixed. Plugged in code reader and found that the "LH" pretensioner was fautly and that was it. Read up on this issue, so i tried to unplug and clean out the yellow connection under the drivers seat.. Did so and plugged it back in and no more light!
