Operation Magpie.
Old Jan 21, 2019 | 01:17 PM
  #511
Saturnine's Avatar
Well, had fun dealing with this tumbler this AM. My keyless entry has never worked so always just used the key -- no biggie. Yesterday, the key would not turn at all so i had to figure out what was going on. Looks like the locking wafer broke, good thing i snagged a tumbler from the junkyard to pick parts from. The broken bit was lodged and wouldn't allow for any movement. Took everything apart and cleaned it up making sure not to misplace and of the small *** springs. Finally got everything back together along with relubing the assembly -- smooth as butta now!
Old Jan 21, 2019 | 03:18 PM
  #512
You are a better man then me. I would have just stopped locking my truck
Old Jan 21, 2019 | 03:57 PM
  #513
The Deputy's Avatar
Nice job.
I've started considering leaving the keys in the ignition, running, full tank of fuel, couple gift cards, fruit basket and a thank you card...inside the new grey one.
Brian.
Old Jan 21, 2019 | 07:37 PM
  #514
Saturnine's Avatar
Don’t do fruit baskets, no one will take it for sure
Old Jan 22, 2019 | 02:48 AM
  #515
The Deputy's Avatar
Okay, l'll add some steaks and beer to the pot. That way l rule out just getting vegans. Trying to be more inclusive and all...lol.
Old Jan 22, 2019 | 09:40 AM
  #516
Saturnine's Avatar
Hahahaha
Old Jan 22, 2019 | 02:44 PM
  #517
Saturnine's Avatar
Wifey asked me to get some eggs this AM and i took the long route
While bumming around, i noticed that the UG was displaying 13.2x volts which wasn't good. It took me a few mins of "wtf" thoughts before i realized that the heated windscreen was turned on. I have always had a huge crack across mine so I know it doesnt work -- i guess when the HVAC is set to auto it'll sometimes auto turn on the HFS. Switched off the HFS and the volts instantly jumped back up to 13.9x which is where the voltage usually hangs out at. Probably going to yank the 2 fuses until i get this damn windshield replaced
ALSO
I installed the extended roof rails yesterday. It was sunny and warm (50's) so i just decided to go for it. Super easy to do.. In theory. All was well until one of the damn studs stripped out in the base of the extended rail. This literally would have been a 30min job tops but it took me close to 1.5 hours. Ended up drilling the hole in the base of the extension rail out a tad more and tapped it out. Luckily had a bolt that was the same size/pitch as the stud but a bit longer -- was able to get things nice and tight.
Now just gotta paint the headliner and i can get everything back together. Still gotta figure out how i want to run aux wiring.. err use the existing aux wiring that the PO had left behind. Bought some terminal strips so probably be installing one of those for 12v power in the rear so that its easy to tie into 12v later down the road for what ever items.
Old Jan 22, 2019 | 05:21 PM
  #518
Saturnine's Avatar
Well, i yanked the 2 40amp fuses (F7&F8 in the engine bay) for the HFS and it made quite a difference in voltage according to my UG. Usually in the 13.9x range but now my UG reads in the 14.3x range
Old Jan 22, 2019 | 08:26 PM
  #519
wouldn't have expected that
Old Jan 22, 2019 | 08:40 PM
  #520
Saturnine's Avatar
Expected.. as little snow as CO got?
