Operation Magpie.
Old Dec 6, 2020 | 03:54 AM
  #671
The Deputy's Avatar
Yep, l've replaced brake fluid in every rover so far...and all were like honey beforehand.
Old Jun 29, 2021 | 10:16 PM
  #672
Saturnine's Avatar
The Denver roads finally did Magpie in.. I have patched each tire at least 4-5 times and finally just have to call it quits. New tires are on order, ugh. Buying tires are the worst.
Been driving the Vw for a while now, way better mpg and a lot more fun to drive.
Building a house currently, so money is tight. Need to get that AC recharged!
There is a Defender 110 "full" roof rack for sale locally for $100, might go an pick it up. Seems to be a home brew dealio, but made from 1x1" steel - probably 11 gauge. Should do the trick..!
Old Jul 19, 2021 | 07:29 PM
  #673
Saturnine's Avatar
Beefed up the OEM tire carrier today, things were cracking and needed to be fixed!
Observe the Problem at hand:
Yep, that sh*t is cracked. 2 of the 3 studs were like that, and the 3rd was on its way to the same fate. Game plan is to make a backing plate for support and beef up the structure in general.
Drew up an idea and headed over to the mill to execute. I decided that 3/16 plate would do the trick..!
Welded in after grinding off paint, fixing the cracks and did a rosette weld to the studs to actually attach them to the added plate.
Added straps to add some rigidity to the structure -- also welded the spacers to the actual carrier.
Added large washers to the front for more support.
Ready for paint.
Went with bed truck liner because.. thats all i had.
Installing tomorrow!
Old Jul 19, 2021 | 08:16 PM
  #674
Excellent work
Old Jul 19, 2021 | 09:12 PM
  #675
Saturnine's Avatar
Thank you sir.
Got some new rubber finally. Decided on some Cooper Maxx ST's (err ST Maxx? -- whatever)
Liking them so far
Attending to the rear bumper and exhaust next..
Old Jul 19, 2021 | 11:05 PM
  #676
Fastercat's Avatar
Lookin good
Old Jul 21, 2021 | 02:59 AM
  #677
The Deputy's Avatar
Is the front bumper for the rover, too? Tire carrier turned out nice.
Old Jul 21, 2021 | 06:55 AM
  #678
Saturnine's Avatar
I wish! That’s an Earthroamer LTi rear bumper
Old Aug 1, 2021 | 06:08 PM
  #679
Saturnine's Avatar
More busy work..!
The rear taillight guards were always a little tatty, so I decided to clean them up - grind off all surface rust and give them a repaint. Took a lot longer than I thought it would but came out.. Ok. I still might have them blasted and powder coated but we'll see how they hold up over the winter.
Replaced the SAI pump mounts with some new Dorman stuff - worked like a charm. The old mounts were certainly toast.
Also chasing down a battery draw that ive had for a few months now along with some new codes.
If I don't drive MagPie within a week the battery will be dead. Did a test today.. Something is certainly going on
Had about .1mA draw across the negative cable / Neg battery post via multimeter. If I pulled:
F20 (Interior fuse box - 15a - Transponder coil, header 294, header 72)
F13 (Engine bay fuse box - 10a - Inertia switch, BCU, IDM, instrument pack)
F11 (Engine bay fuse box - 30a - SLABS ECU)
- the draw would basically go away. So gotta figure those out
Oh, and this happened. Going to just lop off the end and weld on a new tip for a quick fix.
Oh yah, codes. P01171 and P01174. Got my hands on a full set of Walker O2's so hopefully those codes will go away. Ive had P0134 code for a while now, just always cleared it until the other 2 codes started showing up within the last few weeks.
Old Aug 1, 2021 | 09:34 PM
  #680
My excursion did a similar exhaust mod to itself a couple weeks ago about 500 miles into 4000 miles of towing. Good news was mine was under the second row seat area and right before the muffler......
