Super Model With Bad Crack Habit Rehab Build-
Old Oct 25, 2015 | 06:23 AM
  #71
Detoured Discovey's Avatar
Originally Posted by ihscouts
It is and so is the crappy idle.
ECM = Enigma Code Machine
You'll find that in engine bay, passenger side, up against firewall in between hood hinge and windshield washer fluid bottle.... It has a black (plastic) shroud with a picture of Jesus on it.
BWAAAAAHAAHAAAAAAHAAAAAAAAAAAAAAA!!!! Love it!
Old Oct 25, 2015 | 09:03 AM
  #72
TOM R's Avatar
Passenger side back of wheel well, bolted flat to the cage, plastic cover is held with plastic trees
Pull ecm look for hole in wheel well and case , awesome design
Old Oct 25, 2015 | 09:56 AM
  #73
LOL......I had to replace that hole wheel well with 4" of new steel.
I had all that wheel well stuff off and die-electriced all the connections that I could get my grubby hands on......Can't wait to do the driver's side!!!!!!!
Ya, helluva design.......I hope these people weren't allowed to breed.
Old Oct 25, 2015 | 10:02 AM
  #74
So the big box stuffed in the corner.........Got it.
LOL.....Look at this one!
It really looks like a good, promising unit for 2 bills.....lol!!!!
Think his wheel wells were rusting?
1997 1998 1999 Land Rover Discovery Engine Computer ECM PCM MKC104620 | eBay
Old Oct 25, 2015 | 10:05 AM
  #75
Unfortunately they did that is how we got the freelander...
Old Oct 25, 2015 | 10:41 AM
  #76
ihscouts's Avatar
Yet another ticking time bomb of a design........
IF you need to buy an ECM contact Will Tillery or just go to any bone yard cuz it's so well hidden nobody knows it's there and you'll get it for less than three digits. We'll cross that bridge when we get there........ yours runs. Usually when the covers are compromised and there's moisture damage the mighty 4.0 don't run or start.
Old Oct 25, 2015 | 10:56 AM
  #77
I'll see if I can't take a closer look at it later today.
There's a number of them on ebay for 50 bucks.
I'm thinking I need to match up the numbers if I need one......Is it plug and play or more to it than that?
I may actually try to adjust the idle as well, just a touch.....I'm sure there's some wear there after 137k.....
Old Oct 25, 2015 | 04:06 PM
  #78
TOM R's Avatar
U need to be sure u get right one cause there is ael and non ael
U ever get the TPS idle value?
Old Oct 25, 2015 | 06:11 PM
  #79
No Tom I haven't.......another full day between the shop & home life attempted to be squeezed in........The one thing I lack is free time!
TRICK or TREAT..........
OHH Wait.....I know, silly me..........TRICK!
Old Oct 25, 2015 | 06:18 PM
  #80
ihscouts's Avatar
Originally Posted by TOM R
U need to be sure u get right one cause there is ael and non ael.
Hold on a second...... If it's non-AEL you can use an AEL and the later the better because there had been updates to the proms. If you have an AEL you must stick with AEL. Round charcoal can is non-AEL, squarish on it's side is AEL. What happens when an AEL motor is started is the fuel tank vapors are purged, it's an embedded routine in the prom, it also uses the tank pressure sensor to vent back to the charcoal can. Non-AEL doesn't care, it MAY set a CEL but usually it doesn't, the purge routine gets nodded off without setting the Check Engine Light.
Where I'm going with this is the alarm box, the AS10 can make or break the change in ECM's. I've always paired the two from the same truck, my buddy on the other hand did not and it had no effect. To be safe I suggest pairing them. We had a long thread on another forum about this way back in the day.
We don't know for certain the ECM needs replacing so lets let this sit for awhile until the codes are purloined off the existing box. I've let Detour know what's what there and we'll see how it goes.
