Super Model With Bad Crack Habit Rehab Build-
Old Oct 23, 2015 | 12:35 PM
  #61
Detoured Discovey's Avatar
Wife's out in the Disco........No phone calls yet....lol!!
Old Oct 23, 2015 | 02:58 PM
  #62
Cell phones don't work in a broke down Land Rover... Thought you knew.
Old Oct 23, 2015 | 04:32 PM
  #63
TOM R's Avatar
Buy her an lr3, she will never complain bout the d1 again lol, that's what I did
Old Oct 23, 2015 | 08:18 PM
  #64
Just the warmed up ruff idle issue I warned her about.....need to address this, I drove it later for a 2 hour round trip.....idle rough at stops, but while cruzing it's fine........dunno, may have to purchase bullets....
Old Oct 24, 2015 | 01:49 PM
  #65
TOM R's Avatar
Cleaned throttle body
Cleaned IACV
New pcv hoses
Clean pcv
Add grounds at battery, one to engine one to rad support
Fuel filter
Tune up
I am sure u did all that, what it TPS value at idle? Might need ecm values reset or ecm rusted through case
Old Oct 24, 2015 | 02:52 PM
  #66
ihscouts's Avatar
Yah, any codes pop'n?
Old Oct 24, 2015 | 03:39 PM
  #67
[TOM R ...
Cleaned throttle body......Yep
Cleaned IACV.................Yep
New pcv hoses............... Looked fine but I'll double check
Clean pcv......................Yep
Add grounds at battery, one to engine one to rad support.......Yep
Fuel filter........Yep
Tune up..........Yep
Took every ones advise from prior trouble shooting right down to die-electric on connections......Premium fuel....all the above, throttle body twice.
The ac compressor needs to be replaced, wonder if it's causing drag as the bearing in the back is bad/noisy.....probably not, just a thought.
ECM ....drawing a blank, short for and where can I find it?
Look's good sitting in the driveway though.......
Old Oct 24, 2015 | 03:43 PM
  #68
Don't see any codes, engine light is always on.....thought that was standard equipment though...
Old Oct 24, 2015 | 07:35 PM
  #69
ihscouts's Avatar
It is and so is the crappy idle.
ECM = Enigma Code Machine
You'll find that in engine bay, passenger side, up against firewall in between hood hinge and windshield washer fluid bottle.... It has a black (plastic) shroud with a picture of Jesus on it.
Old Oct 24, 2015 | 09:17 PM
  #70
TOM R's Avatar
How is engine light on but no codes?
