Worlds longest slowest 110 build thread
Old Dec 6, 2019 | 11:50 AM
  #261
The Deputy's Avatar
Lucked out at our DOT...she couldn't find any info on defenders...so she googled them. Came up with a bunch of junkers for sale in the UK. When she said...how does 5K sound for a value? I said...well, it sounds a little high...but I guess that's okay.
Old Dec 6, 2019 | 01:42 PM
  #262
I got lucky with a military exemption
Old Mar 22, 2024 | 07:15 AM
  #263
So it has definitely been a minute. In the meantime we have had Rona, my retirement from the Army, my getting my first civilian job as a parts and service guy at Harley Davidson and rising to Parts Manager, leaving to go back as a civilian working for the military and starting my own side gig selling used parts.
Out at my shop I finally had time and a goal so let’s see if I meet it this time. So I pulled the 110 from its resting place in the garage and got it in my shop so we could get going
Old Mar 22, 2024 | 01:40 PM
  #264
There was damage to the front axle housing so I sourced a used front and rear axle for it and got to tearing it down for rebuild. In a holding pattern on this one for a few parts. Locking diff and upgraded axles will be going in along with vented rotors
Old Mar 23, 2024 | 06:54 PM
  #265
Got the rust cleaned up and treated on the front wheel wells and some fresh undercoating. Man I cleaned a lot of dirt and crap out of the front end of this thing.
got to keep progress rolling
Old Mar 24, 2024 | 07:37 PM
  #266
So with the front axle tear down I had a few bits that I had to run by my local machine shop fora bit of love and oddly I was out of gaskets for diffs so I had to ring up lucky8 and get a 10 pack coming. The front axle is getting Ashcroft axles and E locker. Back will be getting the same.
The lt95 has gotta go and I have a LT85 and LT230 that I am going to replace it with. So it will have the ability to lock all three which is awesome.
I have a TBI injection set up from Aces Fuel Injection that will be going in. I really don’t want to do an external pump so I am going to see if a D1 or RRC tank can be used with the in tank pump set up.
So I decided it was time to drop the tank. Yeah it smelled terrible.
Old Mar 25, 2024 | 02:58 PM
  #267
So I had a plastic tank D1 that was most of the way out already from pulling parts off that truck so I dropped it and drug it in the shop. That was a no go it has a section that wraps up over the frame rail that hits straight into the body mount for the tub support. I peaked under a Range Rover and its plastic tank was the same but another older truck had a steel tank that is a perfect match so I got it dropped out and gave it a test fit. Looks like a winner
Old Mar 26, 2024 | 12:49 PM
  #268
Had to check out the fuel pump and inside of the tank from the RRC. So I set to work on popping the pump out
couldn’t believe it
so inside the tank was fantastic the pump looked new and worked fine so I’ll do a clean up and on the outside. Then it will be ready to go once I get the welding done, undercoat and axle back in.
thinking I should look at doing a fuel pump access plate in the tub of the 110 for serviceability 🤔
Old Mar 27, 2024 | 01:28 PM
  #269
Moved on to dropping the exhaust. Need it out of the way for the transmission to come out and it needs to be replaced regardless so out it goes. I have something really cool I think to replace it with. So had to start with pulling the exhaust manifold nuts on the y-pipe. I know you can feel my excitement on that one 😂
Old Mar 28, 2024 | 12:12 PM
  #270
Cut the fuel filter mount off the RRC frame and will be transferring it over to the 110 frame to keep it all sorted nicely.
I removed the Salisbury rear axle and will be putting a Disco axle with disc brakes, a locker and upgraded axles back in its place. I apparently forgot to let it out however
