"You should just get a Jeep"... My 04' Disco Build Thread
Old Apr 29, 2020 | 10:47 AM
ahab's Avatar
I wasn't aware of a flange conversion. I assume this eliminates the guibo? (that's the weird name for the donut).
Old Apr 29, 2020 | 11:01 AM
whowa004's Avatar
Yes if you upgrade the rear driveshaft you have to convert the flange on the diff side to remove the flex piece.
Old Apr 29, 2020 | 11:02 AM
Gallep748's Avatar
Yeah, this was news to me too. After some quick research I've seen guys rip apart the rubber donut on the trails and went with this metal/metal conversion. It makes sense, we'll see how it matches up in about a week when I install everything.
Old Apr 29, 2020 | 11:04 AM
Gallep748's Avatar
Will I need a spacer?
Old Apr 29, 2020 | 11:20 AM
ahab's Avatar
I can only assume they rip apart worn out donuts. I have a 350hp BMW which regularly sees 7000 rpm shifts and I've yet to have a problem with the flex disc. My daily driver has at least 200k miles on its flex disc and it's fine as well. This one has 100+hp less but isn't exactly babied either. That's not to say they don't wear out or fail, but I don't think simply not having one in there is an upgrade in my opinion. A lateral move at best. I'm certainly open-minded about being educated on what I'm missing however. Perhaps severe articulation puts additional strain on them which they weren't designed to handle.
And sorry, not ignoring the spacer question, I just don't know the answer.
Old Apr 29, 2020 | 11:23 AM
whowa004's Avatar
I'm unsure of on the spacer. In my mind the flex piece helps keep some strain off the weak stock diff, also I haven't needed to upgrade my rear driveshaft yet and I keep a spare flex disc in the car and it's a easy trail fix if I do blow mine up.
Old Apr 29, 2020 | 04:29 PM
The Deputy's Avatar
Congrats, looks like you're off to a great start.
Brian.
Old Apr 30, 2020 | 03:43 PM
Gallep748's Avatar
While waiting for parts, I decided to get the headlights refinished.
Before refinishing
After refinishing
Old May 2, 2020 | 03:34 PM
Gallep748's Avatar
Parts have finally come in. Need some help with the Terrafirma lift.... https://landroverforums.com/forum/ge...co-2-a-100123/
Old May 29, 2020 | 08:38 AM
arains44's Avatar
Did you refinish the headlights yourself? I'd love to do that with mine, huge difference!
