Defender Talk about the Land Rover Defender within.
200TDi wont go over 30mph
Old Oct 14, 2018 | 07:42 PM
mike defender90's Avatar
5th Gear
Default 200TDi wont go over 30mph
Hi all, I am new to the group I have just purchased a Defender 90 200tdi.
I am unable to get over 30mph. The engines fires up first time without fail.
Any suggestions or advice would be greatly appreciated.
Thank you
Old Oct 14, 2018 | 07:47 PM
Guessing it feel down on power. Is it smoking what are your temps looking like? Are you in high range?
Old Oct 14, 2018 | 07:50 PM
5th Gear
As far as I know it is in High range the gauges arent working and get a lil bit of smoke during start up but whilst running.
Old Oct 14, 2018 | 08:55 PM
Is it going through the rev range just fine in all gears?
Old Feb 1, 2019 | 01:15 AM
5th Gear
Its my first Defender so not sure about the speed of which it goes through the Revs. It does seem pretty slow. Once it hits 30mph nothing much seems to happen.
Old Feb 5, 2019 | 02:14 PM
DavC's Avatar
where are you located?
you're sure you are in high range? lever should be towards the rear of the car
My initial thought is a fueling/timing issue. Like someone turned the fuel waaay down or retarded the timing, or both.
Old Feb 6, 2019 | 12:06 AM
5th Gear
I am from the north east. Newcastle. The lever is in the back position. I bought it from a friend who hadnt had it long. Not sure of how long it was sitting for our when the last time it was serviced.
QUOTE=DavC;679305]where are you located?
My initial thought is a fueling/timing issue. Like someone turned the fuel waaay down or retarded the timing, or both.[/QUOTE]
Old Feb 8, 2019 | 01:46 PM
DavC's Avatar
Ok if you are in the UK just take it to a good mechanic and have them retime it and re-set the fueling.
Since you got it, have you changed the oil and fuel filters? If it has been sitting for a while you may try swapping the lift pump (cheap), are there any diesel leaks you can see? Will the turbo spool up? Check for broken boost lines.
Again, a mechanic will be able to sort it
Old Feb 8, 2019 | 07:38 PM
5th Gear
I havent had the filters or oil changed as of yet. I bought it on a whim without a garage so had to build a garage first. Trying to gather as much information as possible before I do anything. Its something I want to try and tackle myself so Appreciate everything.
Old Feb 12, 2019 | 02:48 PM
DavC's Avatar
I can understand you wanting to DIY but,
You need to have a good baseline to start with unless you have prior experience on these motors. A good mechanic in the UK (again, I am presuming you are in UK?) will not cost too much to take a look at the timing and fueling. You should find one and have it gone over in a very basic way. You can even ask them to do some work on it and show you what they are doing and why.
For instance, if your timing is off or a belt is broken you will damage the motor trying to run it without knowing what is wrong.
At least change the fluids, clean up the motor as much as possible to find leaks, and start noting symptoms or take videos and ask someone to compare it with a running Tdi.
Again, are you seeing any diesel leaks? are you seeing leaks at lift pump, injection pump, injectors? Are you getting the turbo to spool? What kind of smoke are you getting from the exhaust? Please report back if you want more help here.
tombartley
Sep 15, 2014 06:18 AM
brian p
Defender
Aug 6, 2012 05:57 AM
Skimino Farms
Jul 30, 2011 07:47 AM
JamesS
May 3, 2011 04:31 PM
luxury1
16
Dec 28, 2008 02:07 PM
