Defender Talk about the Land Rover Defender within.
briansoutham
Old Sep 18, 2021 | 11:45 PM
Briansoutham's Avatar
Default briansoutham
Landrover how do I solve overheating problem.defender110.TDI300
Old Sep 19, 2021 | 08:20 PM
More info needed, what steps have you done what are the symptoms etc
Old Sep 19, 2021 | 11:43 PM
Water pump,Thermostat,Radiator have all been changed.Teperature intermittedly rises to red.Temperature sender has been changed.Top hose is cold.Radiator temperature is 16degrees celsius.Earth wire fitted from engine to bulkhead.System is well bled.what could it be.I am going to try a genuine Thermostat.
Old Sep 22, 2021 | 01:58 AM
The Deputy's Avatar
Are you checking actual engine temps with IR gun? These gauges and sensors are so unreliable, that actual readings from engine compartment tell me more useful information. If it's actually getting hot, verified by IR gun, then, might be time for a new viscous fan...or upgrade to electric fans.
Brandon318
Jun 8, 2019 05:41 AM
Mooseman
May 28, 2019 03:08 PM
holland
Freelander
May 13, 2009 02:57 PM
paweliania
Freelander
May 2, 2008 10:02 AM
