Defender Talk about the Land Rover Defender within.
Broken Universal Joint
Old Aug 18, 2007 | 03:29 AM
Mountainman's Avatar
Default Broken Universal Joint
Greetings,
Here's my question. I broke the front U-joint on my 1986 110 yesterday. Now being the shade tree mechanic that I am I figured I could just take the front drive shaft off and go on my merry way. But when I got in and put her in gear nothing happened. Is there away I can get this moving without having the front shaft installed? Last time this happened to me I was in a Chevy, but it was not a full time 4x4. Any suggestions would be great. Its along way to the Land Rover shop for parts And would like to get it home without the help of a wrecker.
Thanks,
David
Old Aug 18, 2007 | 10:24 AM
Adz's Avatar
Adz
Default RE: Broken Universal Joint
If you've completely removed the front prop - then put it in difflock and it'll drive. Don't use difflock if both props are attached, you'll knacker the transfer box.
Old Aug 18, 2007 | 11:30 AM
Hey ADZ, I tried to that but, it still didn't move. I was wondering if the Diff needs to have some kind of resistance from both shafts to operate?
Old Aug 19, 2007 | 01:21 PM
Adz's Avatar
Adz
Put main box in first gear, transfer box in high ratio, lever across to the left to engage difflock and try to drive it. If the car doesn't move, it's probably because the difflock isn't engaging - you can try rolling the car forwards by pushing it with it in gear - you'll need an assistant for that (or several more likely) as leaving the car in gear with no-one at the wheel is a great recipe for a runaway car. Good luck.
Old Aug 21, 2007 | 04:44 AM
Thanks Adz, That worked! Got the beast home and the new universal is installed. One last question? Is there a good rule of thumb for the frequency that yoiu need to lube the universals? I usually do it every time I change the oil, but maybe I need to lube these more often.
Thanks, David
Old Aug 21, 2007 | 05:04 AM
Adz's Avatar
Adz
At least every oil change - I regrease mine every time I use it off road and I change the swivel hub oil each time I use it for wading.
Cheers,
Old Aug 22, 2007 | 02:46 AM
Thanks for the info!
David
Old Sep 4, 2007 | 12:15 PM
antichrist's Avatar
ORIGINAL: Mountainman
Usually that's good enough, assuming you don't go 10,000 miles between oil changes.
When greasing you should get grease coming out of all 4 seals, if not, not all the journals are getting grease.
thelod
Jan 5, 2013 01:44 AM
Pacific Graveyard
Aug 23, 2012 11:10 PM
LeakyDisco
Sep 29, 2010 10:56 AM
98P38
Dec 28, 2008 01:30 AM
JBEGIN
Nov 4, 2008 11:58 AM
