Defender Talk about the Land Rover Defender within.
CA Smog Test - '95 Defender 90 NAS
Old Sep 13, 2024 | 12:26 PM
Truckeegame9's Avatar
Default CA Smog Test - '95 Defender 90 NAS
Hi - I am a California resident and recently purchased a 1995 Defender 90 NAS with a 3.9L from out of state. I now need to pass a CA SMOG test and failed my first try yesterday due to a 234 HC reading at 2,500 RPM (vs a 170 HC max). Has anyone here had any luck passing CA SMOG, or have any ideas on lowering the HC reading? My amateur googling has informed me that given I have high HC readings but good CO% results that the catalytic converter is probably OK, and that the issue is likely driven by spark / ignition / timing. I am debating adding a can of sea foam before the next test, but don't want to trade one problem for another... Any thoughts or advice would be appreciated.
Old Sep 18, 2024 | 05:50 PM
giddy-up's Avatar
While I cannot answer your question. Check out nas-row.com or defendersource.com someone over there should be able to help out.
stephenzeek
Defender
Sep 28, 2024 06:54 PM
3mran
Defender
Aug 2, 2021 04:54 PM
JoeGaska
Defender
Jun 14, 2021 01:52 PM
Trivett99
Defender
Feb 3, 2021 01:25 AM
russcarm
Defender
Oct 18, 2006 01:00 AM
