Defender Talk about the Land Rover Defender within.
engine identification
Old Sep 25, 2006 | 08:19 PM
Punter's Avatar
4th Gear
Default engine identification
Does anyone know where I can find some sort of resource that will help me to identify an engine?
I've got a Defender with a V8 Petrol engine in it... I believe it is a 3.5L (but I suppose it could be a 3.9L). The vehicle had been pieced together from a number of others, and I do not know the source of the engine.
I have located the serial number on the block and I would like to know if there is some resource that I can referance which will tell me exactly which engine this is and when it was produced; so that I can be sure I'm referancing the correct shop manuals.
Thanks,
Punter
Old Sep 26, 2006 | 12:28 PM
Default RE: engine identification
Best contact your Rover dealer or shop, I don't believe the engine serial number will tell you anything I know the VIN will tell you what the truck came with.
Wish I could be more help.
Mike
Old Nov 3, 2006 | 05:58 PM
Old Off Roader's Avatar
No problem!
The number on the left bank of the block will start out with 2 numbers and a letter. This is the engine code and will tell you engine size and application. Here is a quick list!
31D--3.5 litre
36D-- 3.9 litre Range Rover and Disco 1993-1995
38D-- 3.9 litre Range Rover 1989-1992
40D-- 4.2 litre Range Rover 1993-1995 LWB only
42D-- 4.0 litre P38 Range Rover 1995-1998
46D-- 4.6 litre P38 Range Rover 1995-1998
50D-- 4.0 litre Disco Series 1996-1999 manual and auto
I doubt you will need the Bosch numbers, but if you do.......
Old Mar 31, 2012 | 08:49 AM
JohnF's Avatar
5th Gear
What is an engine starting with S70D?
Originally Posted by Old Off Roader
No problem!
31D--3.5 litre
Old Nov 3, 2015 | 02:19 PM
drowssap's Avatar
Good imformation thx
No problem!
31D--3.5 litre
Old Apr 12, 2016 | 12:27 PM
lr1022's Avatar
Default Engine identification number
Is anyone out there able to help me figure out what my engine identification number means do I have a 4.0 or a 4.6?😖
Engine # S87D01088A
Old Jun 22, 2021 | 09:49 AM
tes1368's Avatar
Default Engine numbers
Can anyone help have an engine from a 1972 Range Rover but only numbers I can find on engine is as follows 31D PH1 026 R. CR8. 1311
Old Jun 23, 2021 | 03:25 AM
The Deputy's Avatar
According to the list provided...31D = 3.5 liter.
Old Jul 6, 2022 | 04:57 AM
Philsn's Avatar
Default Code V8
Bonjour je cherche à savoir à quoi correspond le code moteur 08D28108A
CR 9,37:1 merci
roversland
Feb 20, 2022 11:56 AM
drummerdimitri
Sep 15, 2012 09:33 AM
georgep
Feb 12, 2012 12:12 PM
momentum59
Sep 4, 2008 12:20 PM
cjn104
Sep 21, 2004 09:31 AM
