Need help identifying engine displacement
Old Oct 4, 2011 | 03:20 PM
drummerdimitri's Avatar
8th Gear
Default Need help identifying engine displacement
Hello guys,
I currently own a 2003 land rover discovery II with the v8 engine, but I am having a hard time identifying whether it's a 4.0 or a 4.6 L engine. Is there an easy way to tell the difference? From what I've seen on the web, both engines look exactly alike from the exterior, but I was wondering if there were minor physical differences. Also, I know that the old 4.0 engine was replaced by the 4.6 L engine in 2003, but for some reason, I am not convinced that my disco has the later one. If there are any obvious physical differences, then please try to illustrate it on an engine's picture as I am not very good with the technical terms.
Thanks!
Old Oct 4, 2011 | 03:23 PM
You have a 4.6 not a 4.0, what are you worrying about?
Old Oct 4, 2011 | 03:29 PM
8th Gear
I'm not worried, just curious...
Old Oct 4, 2011 | 06:03 PM
If your engine has been swapped you will need to find the serial number stamped on the block and then have the dealer look it up.
Old Sep 15, 2012 | 04:21 AM
8th Gear
Will a picture of the engine itself be enough to make sure I have the 4.6?
Old Sep 15, 2012 | 04:46 AM
Nope. You could have heads from one engine and block from another. If you really want something to worry about, buy an Ultra Gauge and start looking and digital coolant temp..... or start thinking about what your oil PSI really is doing.... or that front propshaft that has not been rebuilt.... or the radiator full of Dexcool mud... And meet the therapist for these issues....
Attached Thumbnails Need help identifying engine displacement-pittsburgh-20120905-00034.jpg   Need help identifying engine displacement-dex-cool-2.jpg   Need help identifying engine displacement-bad-mechanic.jpg
Old Sep 15, 2012 | 09:33 AM
So, you don't listen well, all 03 and 04 's have 4.6 engine from the factory and as already mentioned they both look the same a a engine serial # is the only way to verify thru a dealer.
daxter1987
Apr 30, 2018 11:51 AM
atancreti
Oct 11, 2012 09:02 AM
Classklown90
May 13, 2011 09:15 PM
Cyberbaker
Jan 4, 2011 06:10 PM
Vicks
Mar 14, 2010 12:21 PM
