Defender Talk about the Land Rover Defender within.
Fog light fuse blowing. Any ideas????
Old Jun 24, 2007 | 01:19 PM
Jameslandrover110's Avatar
Default Fog light fuse blowing. Any ideas????
I have a Land Rover 110 and the fog light fuse had blown so i replaced it with the 8 amp fuse and as soon as the fog light is put on the fuse blows. I tried putting a 25 amp fuse in and it did not blow but the fog light still didn't work. Has any one had the same problems? Any ideas anyone?
Old Jun 25, 2007 | 03:14 PM
Adz's Avatar
Adz
Default RE: Fog light fuse blowing. Any ideas????
Have you tried changing the bulb?
Sounds like you've got a short in the fog lamp circuit somewhere at a guess... could be the bulb, first thing to check anyway. If it's not the bulb, it could be the bulb holder is corroded badly - if that's the case it usually makes getting the bulb out a bit more difficult so you could probably take that as a pointer if it's a pig to remove.
Let me know if that checks out ok and I'll see what else I can come up with.
Cheers,
Old Jun 26, 2007 | 01:39 PM
I have checked the bulb and buld holder, also removed it completly each time testing the fog light and still its blowing the fuse. I have also checked the the switch itself but still the sameproblem. Asyou saidi think itsa short in the circuit.
Old Jun 28, 2007 | 01:01 AM
Mountainman's Avatar
Hey, Just thought I'd put my two cents in. I have a 110 also and had the same problem. It ended up being in the switch. Sometimes it worked sometimes it didn't. I replaced it and it went away.
David
Old Feb 18, 2011 | 02:46 PM
djjakubik's Avatar
I know this is an old post, but my 06 lr3 hse seems to have a bad fog lamp circuit. Does anyone have a solution? Is this something I can fix or do I need to take it to the dealer?
gillart
Jan 7, 2015 07:12 PM
cevans03
Sep 25, 2012 11:31 AM
morris27
Apr 30, 2011 04:58 AM
Damiean
Aug 22, 2007 01:34 PM
mikemeyer0
Apr 1, 2005 02:03 PM
