Fog lamps blowing fuse
Old Sep 25, 2012 | 09:34 AM
cevans03's Avatar
Default Fog lamps blowing fuse
Help I have changed out the fog lamps replaced the fuse but the keep blowing out... on my 2008 LR3
Old Sep 25, 2012 | 11:31 AM
unseenone's Avatar
There was some discussion of issues on some LR3 some time ago, where the wires would sometimes rub and short out. To check it, you need to remove the assemblies and inspect the wires for rubbing, and take corrective action as necessary.
Pull out your fog light circular trim (use a small flat screwdriver to help), then unscrew the retaining screws and pull the light forward. Now check the wires- you will most likely find a small area of damaged insulation - it rubs on the steel framework. Wrap it in insulation tape, (each wire separately then together) then put it back together. Replace your fuse after you have done both front fogs.
Takes about 15 minute per side and a few minutes with the fuse.
gillart
Jan 7, 2015 07:12 PM
rambo
Oct 17, 2013 10:13 PM
Jameslandrover110
Defender
Feb 18, 2011 02:46 PM
DV57
Jun 28, 2007 11:55 AM
A12LR3
Nov 12, 2006 11:20 AM
