Defender Talk about the Land Rover Defender within.
Front axle spindle bronze bush wear
Old Jul 8, 2024 | 04:03 PM
Dklein82's Avatar
3rd Gear
Default Front axle spindle bronze bush wear
Hey I recently replaced the passenger side axle shaft and all the axle seals and bearings as well as the bronze bushing on the backside of the spindle. After a couple weeks I took the axle out to look at a differential noise and noticed the swivel ball fluid has bronze flake in it and the bronze bushing was slightly worn. I also noted there was a little more end play in the outer axle shaft at the snap ring and probably need to measure for a new spacer washer. Could that be the reason for the excessive where on the bushing or should I look elsewhere?
martinezparamounttkd@gmail.com
Dec 28, 2021 04:39 PM
Shiftonthefly1
Nov 13, 2014 11:55 PM
tweakrover
Oct 12, 2011 11:03 PM
GROVERtheROVER
Aug 29, 2011 09:37 PM
kymike
Apr 24, 2009 01:17 PM
