swivel ball removal
Old Oct 12, 2011 | 08:09 PM
tweakrover's Avatar
Default swivel ball removal
I'm developing a slight death wobble (caused by a worn lower swivel bearing) which has got me thinking about rebiulding the swivel and resealing it. I'm acctually considering changing the whole axle for one at the pick n pull if i can find a decent one that aint leaking, mine has some play in the diff also. but anyway my thought was why couldn't someone pull the whole end of the axle off from where the swivel ball bolts to the axle housing, for example if you wanted the change the swivel ball gasket without tearing the whole hub and stub axle apart, the cv just slips off the axle shaft right? in my case this wouldn't help but you know how one thought leads to another.
Old Oct 12, 2011 | 08:33 PM
Paul Grant's Avatar
It weighs a ton but by all means you can pull the hub, rotor, swivel housing, spindle, swivel ball, cv and axle by removing the bolts securing everything to the axle casing. Everything will be very unwieldy and well over 100lbs.
Old Oct 12, 2011 | 11:03 PM
tweakrover's Avatar
Cool good to know, like I said it won't help me in my situation but if someone wanted to change the swivel seal without having to tear it all down, I imagine it could be done with a floor jack and a couple guys
hazletbassist89
Mar 25, 2011 02:38 PM
johnkbl
Dec 29, 2008 06:12 PM
reflextuning
Jul 18, 2008 12:03 PM
johnkbl
Oct 2, 2007 07:17 AM
btp226
Jul 12, 2006 05:34 PM
