Defender Talk about the Land Rover Defender within.
Fuel Sending Unit Help
Old Jul 28, 2017 | 02:34 PM
njlandybabe's Avatar
Default Fuel Sending Unit Help
Hi Everyone,
I am hoping you can help me.
1977 Land Rover Santana Series Diesal III 88.
I need to replace the Fuel Sending Unit. It appears the vehicle was fitted with a 109' rear tank fuel sending unit, so the recommended replacement I ordered from Rovers North does not work (SENDER KIT FUEL GAUGE NEG EARTH SERIES, RNC751, 90560612 - Rovers North - Classic Land Rover Parts) . My fuel tank doesn't have the second draw tube for overflow- so I guess they used the 109' fuel sending unit which has the tube attached.
How would you handle this?
A. Drill a hole in the fuel tank and add a second draw tube for the spill back.
B. Use another 109' rear fuel tank spec sending unit. Problem is, this doesn't have the holes on the ring, so I'd have to drill holes and retrofit it.
Photos attached.
Thank you and if there is any confusion, please let me know. Im not sure I did a good job explaining this.
Attached Thumbnails Fuel Sending Unit Help-img_3002.jpg   Fuel Sending Unit Help-img_3004.jpg   Fuel Sending Unit Help-img_3005.jpg   Fuel Sending Unit Help-img_3006.jpg
savgre25
Feb 4, 2011 07:52 AM
kma32254
Dec 2, 2009 09:13 PM
Robmcin
May 10, 2009 05:08 PM
Galaxie_406
Dec 16, 2008 11:57 AM
thehouseofkraus
Nov 25, 2007 07:27 PM
