Defender Talk about the Land Rover Defender within.
Help tdi injector pump replacement and timing
Old Apr 11, 2021 | 10:49 AM
Def-ender's Avatar
Default Help tdi injector pump replacement and timing
Do tdi injector pumps inject diesel to all cylinders each time it rotates or is there a sequesnce of 4 rotations?
backstory: So i have a Frankenstein defender 110 with a 300tdi engine, 200tdi injector pump and an automatic transmission swapped in. My injector pump was leaking. I purchased and used the timing locking tool with one exception that i suspect may be an issue. None of the engine locking pins reached the flywheel. So I removed the injector pump pulley cover and manually turned the motor until the injector pump locking pin slipped in. A professional rebuilt the pump. Upon reassembly, everything primes but the motor seems to be out of time with the pump. I do not want to turn the engine over too much for fear of damage.
metzdmichael
Aug 10, 2018 11:15 AM
OZTRAX
Dec 5, 2012 11:55 PM
andreas78
Jul 26, 2011 12:02 PM
antichrist
Apr 26, 2011 02:00 PM
hagar.T.H
Nov 21, 2010 04:10 PM
